54 ford f100 suspension ?
I just picked up a 54 f100 for a new project. I'm looking into changeing the front suspension out for something that rides better and sits lower. I'm very Interested in doing the 03up crown Vic. Has anyone here done this on the 53-56 trucks? I would like to see pics and talk to anyone that has done this swap on this truck. Thanks Jason
also I have searched and all I come up with is 60 and up trucks with this swap
The following users liked this post:
You will have 1-1/2 inches on each side measured from the wheel mounting flange on the rotor to the inside lip of the fender...that means that you must use a wheel with a massive negative offset so that you can get the wheel and tire up under the fender. I don't understand the fascination that some folks have with the CV IFS when there are so many other IFS units out there that don't have the width constraints of the CV. There have even been recent posts on this forum about how to widen the fenders to compensate for the excessive width of the CV IFS...is the CV unit that much cheaper to warrant flat rims and widened fenders? The reason you find more info on the later F100s is because the track width on the later models is better suited to the wide CV IFS.
Sorry, that was the wrong one....here's the one: https://www.ford-trucks.com/forums/9...-in-56-f1.html
There is a lot of discussion here on the CV swap and I am still of the mind set that the Jag is just as good from a ride and handling standpoint and is the right width for the 53-56. I have it and will be installing it this spring. I know a lot of guys here have done it and ride on it. I got a whole 86 jag for 500 and pulled the front and rear off and all the other things I needed. Also don't let people tell you the parts are hard or expensive for the jag rotors, pads and other parts. They are not.
This was a pretty straightforward install. It actually bolts in, and for all the naysayers out there dont let them slow you down.This crossmember swap isnt too wide, but you will have to run an offset wheel. If you like that look, then you just got rack and pinion steering, huge disc brakes great handling with a big front swaybar, for a fraction and i do mean fraction of the cost for mostly everything else new on the market today. Ive had my truck together and drove it for a while before tearing down to do body work. it drive, rides and handles great. thats my fascination with it anyway.
Just to muddy the waters a little more...go out to a wrecking yard and take a look at how many cars have "bolt-in" IFS units. The way that cars are built today most all have a bolt-in front end. You want performance and luxury ride, try a Lexus SC400 IFS...it's the right width and they can be had at a reasonable price.
Have you swapped the wheels to see how much inside the rear fenderwell they fit? The look may or may not decide what others may do.
EDIT: I'm not one to say this swap doesn't work, I'm just saying one has to prepare for the wheel offset it involves. That affects both front and rear. As a vehicle tracks around a curve, the rear wheels if too far inward will cause a rear roll off center that causes less than ideal handling. This can be fixed by running a wider axle, or wheel spacers, wider wheel, etc... It's a bit of a science, lol.
