choking and splattering
Old Jan 30, 2011 | 12:10 AM
stevenjakeryan's Avatar
stevenjakeryan
Recently i put a 4 barrel thermoquad with vac secondries on my 351 clev and it runs on Gas , i have the choke fully open at the moment with a cable tie as i dont have heat tube connected to exhaust manifold , think its auto choke set up. since putting this carb on it splatters and resists when trying to excellerate and at times seems to be ok until it gets hot and find this is when it starts getting worse . I have tried adjusting gas mixer screw but dont really have an idea which way i need to be turning as it affects idle speed ,so then i up idle on carby to get it back, any idea whats going wrong.
Old Jan 30, 2011 | 02:13 AM
deezyp's Avatar
deezyp
sounds like a fuel issue to me, so the first thing i would check is fuel filters/lines/pump, could also be bad gas or deposits in the line or tank. I seriously doubt you still have a catalytic converter on the truck, so I doubt that'd be an issue. I had a problem with my truck keeping it's idle, and I changed my fuel filters and blew out my lines, and I haven't had THAT problem since.
Old Jan 30, 2011 | 10:23 AM
7Ford6's Avatar
7Ford6
A couple of basic online tutorials on carb tuning.
1. Setting Idle Mixture The Right Way
2. How to Use and Interpret a Vacuum Gauge
granny_rocket
Sep 30, 2013 08:10 AM
Rusty_S
Dec 12, 2012 02:24 PM
berry1234
Sep 22, 2010 09:21 PM
towmater
Jul 27, 2007 12:08 PM
misteramx
Dec 23, 2003 11:06 PM
