defrost default setting
Old Jan 29, 2011 | 07:51 PM
sandmanf250's Avatar
sandmanf250
lost the vacuum pump 2 months ago. replaced. now i,m back to defrost setting.plenty of vacuum to switch to 4 wd .any ideas.
Old Jan 29, 2011 | 08:31 PM
Unrealo4's Avatar
Unrealo4
Does your vacuum pump run a lot or all the time? Or maybe your solinoid is bad sticking the hubs in all the time. There's lots of posts about that soliniod going out in different ways.
Old Jan 30, 2011 | 05:40 PM
sandmanf250
vacuum
hubs go in and out like butter so doe's low range,just the heater settings.(stuck blend door?)
Old Jan 31, 2011 | 11:00 AM
cdevins's Avatar
cdevins
I have e450 ended up being bad vacuum cannister pain to get to, so i plumbed in a new cannister working fine now.
