Ipr coil resistance reading
Old 01-29-2011, 02:19 PM
radracer17's Avatar
radracer17
radracer17 is offline
Hey guys, I keep searching to no avail, but I thought I remember reading that the coil resistance reading was to be between 10.1 and 10.8 ohms. I was going to reseal my ipr, pulled coil and I'm getting a reading of 13, I'm sure that was out of spec, but need some of you to confirm. Thanks in advance!
P.s. My new kit from International didn't include the nut that I remember reading was part of the kit.
Old 01-29-2011, 02:42 PM
tdpower's Avatar
tdpower
tdpower is offline
See Robin's post in this thread (post #20): https://www.ford-trucks.com/forums/1...acement-2.html
Old 01-29-2011, 03:01 PM
radracer17's Avatar
radracer17
Thanks!!! That was exactly what I was looking for, but for whatever reason couldn't find in a search. That's all I needed, well except for an ipr. Lol
Old 04-09-2015, 10:34 AM
jonlb's Avatar
jonlb
jonlb is offline
read the linked thread and?
I pulled the coil off the ipr and checked the ohms. I'm getting steady 9.3. The reason I pulled it is because I'm removing the ipr to clean it due to idle/running issues. I'm wondering if what I'm getting is OK?
Old 04-09-2015, 09:08 PM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
According to PaysonPSD (Robin's) post 20, it could cause it to run badly. He listed an example of one with a .5 ohm resistance lower than the 4 he had been given. Yours is more than an ohm out from that good resistance. However, meters can also vary in their readings depending on several factors.
Old 04-10-2015, 04:23 AM
jonlb's Avatar
jonlb
jonlb is offline
Thanks. I'm going to start a new thread listing my issue and what I've done so far
MDH16
05-21-2017 11:47 AM
wavetrain75
09-09-2016 12:54 PM
12 pointer
16
10-14-2015 10:06 PM
badass_f250
1999 to 2016 Super Duty
09-17-2015 11:16 PM
DBGrif91
08-23-2014 07:23 AM
Quick Reply: Ipr coil resistance reading
