Cruise-O-Matic problems
Old Jan 28, 2011 | 10:40 PM
dsrtjeeper's Avatar
dsrtjeeper
Any tranny experts here? My tranny will not go into gear a majority of the time. If I keep messing with column shifter it will eventually go into gear. The last time I got it into gear; the truck would only move forward even when shifter was in nuetral. I've read different accounts of the internal linkage coming out of a sleeve? The tranny was rebuilt before I purchased the truck. Once you get it in gear it drives and shifts fine but never really seems to take off in low. Any ideas?
Thanks!
Eric
Old Jan 29, 2011 | 09:27 AM
huckdeuceman's Avatar
huckdeuceman
Is the shift linkage adjusted correctly on the trans? sometimes they slip on the lever if
the bolt is not tight??
Old Jan 29, 2011 | 01:56 PM
garbz2's Avatar
garbz2
Is it indexing correctly? There is a guide in side the column that the shifter indexes to and the tangs on the shift arm wear off or the guide breaks.
Is it a green dot? These can sometimes funky shift if the correct pattern is not followed.
Rebuilt by a PO? i would really question that.
I have a good C6 truck builder here at the house if you need it.
Garbz
Old Jan 29, 2011 | 05:08 PM
dsrtjeeper's Avatar
dsrtjeeper
Garbz
Got her fixed Dave! Linkage inside tranny was out of place. Tranny had been rebuilt and never adjusted shift rod correctly. It would go to far into Park and throw the internal linkage outta whack. Shifts like new now. Yes; it's the green dot tranny and I drive it in that position. Thanks for the offer on C-6. http://www.network54.com/Forum/26073...quick+question
Eric
Old Feb 1, 2011 | 12:22 AM
Jim W.'s Avatar
Jim W.
What is the difference in the green-dot tranny v.non? Takes off in second or something like that?
Jim
Old Feb 1, 2011 | 10:01 AM
dsrtjeeper's Avatar
dsrtjeeper
Jim
Basically. When you set shift selector at the small dot or what appears to be Drive; the tranny takes off in second and shifts to third. This was for slippery conditions such as rain and snow. It kept the wheel speed down when taking off. Shifting to the big or green dot and taking off started you in low and shifted up through third. These were called "dual range" C-O-M's. The whole idea confused many drivers thus Ford dropped the design.
Old Feb 1, 2011 | 09:48 PM
Jim W.'s Avatar
Jim W.
Cool! thanks for the refresher. My '64 slick has this tranny. I will have it on the road soon, so nice know!
Jim
73to79
15
Mar 18, 2016 04:32 PM
robsandiego
Feb 5, 2015 11:54 AM
ericr712
Nov 10, 2014 08:04 AM
eb4strom
30
Oct 15, 2014 12:03 PM
f350ford17
Jan 20, 2008 08:54 AM
