I've heard of and also ran Automatic Transmission Fluid in a GMC Diesel that I used to have . I was told it needed it for the injection pump . I'm not sure that it did any good though because it still went bad in the truck twice !! Very expensive to replace injection pump ..
That's normal. You can't fix something that came from the factory broken.
I have Friends that work on Diesels all day long that Run used ATF and Motor oil in there daily drivers. The would put 5 gallons of oil that had been run through a 2 micron filter. This was of course after they let it sit and any water settle out, but I have heard of people running as high as 90% oil or Atf in their trucks. So i doubt your doing any harm at all putting a "whole quart" of 2 stroke oil in the tank.
I run 1/2 a quart per tank in mine, may try some more. Seems to definitely help quiet the injectors. I use the cheap Wal-mart Tech stuff, per the advise on a thread in here awhile back. I'm happy with the results, and have confidence in the good it's doing that I can't see.
