Help! Navigator/Excursion Steering Column Swap- Wiring problems
https://www.ford-trucks.com/forums/9...heel-swap.html
I put a navi wheel in my X, but it was almost plug and play since I already had all the wheel controls. Here: https://www.ford-trucks.com/forums/9...excursion.html
Thanks for the response! Yes, I did read through that thread, and the pictures on page 3 have helped a lot with determining what should be for the cruise side. The problem now is the radio/fan stuff. I haven't seen anywhere if there's a definitive answer on if the radio wires already go to the cruise only wheels. I heard about running a wire for the EATC, but nothing is said about the radio.
I got it all hooked up today and it looks wonderful. Connected everything back up and started it. The airbag light is flashing now and none of the buttons work (not even the illumination). I had a problem with the clock spring when I took it off the Navigator column in that the wire/cable came out of the outer connection. I tried to reinstall it, but I don't think it connected. I just pushed it into the connector because it didn't want to open up without breaking it. I re-spooled the clock spring and centered it, so it should have been good. When I had the vehicle running, I did go to back it out of the garage, and when I got the wheel turned all of about a half a turn to the left, it made some horrible noises. So I suspect I'll be searching for a new clock spring now.
The way I have it soldered up now is all the colors matched except for two from the non-cruise plug and three from the Navigator harness, as I expected this extra wire at the moment. Since the column was from a 2001 Navigator and my Ex is a 2002, I suspected the colors might be the same and it seems like they all go to the same place on both, but I'll never know until I can find a new clock spring.
So for everyone else watching, if you happen to know which wires should be for the radio and which should be for the EATC, I'd appreciate any advice you can give. I have the 6-disc CD AM/FM Stereo and the digital EATC. My Ex should have originally came with the single CD stereo originally, but the previous owner changed it out.
Jon
Now I'll admit there was a light issue when I tried to fit the Navigator clockspring where the plug for the wheel controls didn't want to fit in real well with the airbag. I think it was just where I had it at though, because it wasn't off by much. I'm curious to know though if there are different airbag part numbers, because the plug in connections are the same.
I do have a ton of pictures. I'll try to get them up this weekend at some point. I took pictures of the entire install just like it would be completed and then found out that the clock spring was bad. Took it out for a test drive and the airbag light was flashing. So I had to pull the wheel yet again and I put my old clock spring back in just so I could safely drive it. The good part is, as long as you have the wheel straight when you park the vehicle to do the swap, you can't get the wheel in the teeth just to one side because of some flat spots in it, so it's pretty foolproof. I've done many step by step picture tutorials on the Sunline RV forum before, and I took pictures to do the same here, because it is a subject that I couldn't find that anyone had it on already. My dad and I attempted to repair the clock spring, but we haven't tried it yet since the salvage yard claims to be sending another one my way. We'll see. In my case, the ribbon inside pulled out of the outside connection contact, so after scraping the ribbon down to the copper and soldering it back to the posts, it should be good, but anything is possible. Since it does control the airbag harness too (the clock spring really has two harnesses going through it), I really would rather trust a new one. But I'll see if I get a new one first, plus the cold weather hasn't had me too motivated to go out and pull it apart again...
Oh yeah, and wherever it said on FTE here that you may be able to rock the wheel back and forth to pull it off, nope, not happening. The first time and even the subsequent times after it had just been installed, there was no rocking to get it off... Had to use a steering wheel puller, but it wasn't hard as long as the tool was around.
I'm still looking for any kind of wiring diagrams or information that anyone has on how to wire this up. I went to the dealer about another issue and asked while I was there, but their descriptions only tell the number of pins and the vehicle that it fits on. The Haynes manual only shows limited details, but I have managed to figure out all but two of the new harness wires and one of the old harness wires. Fortunately, a lot of the stuff seems to be the same color and gauge wire, so I'm crossing my fingers that it'll work.
Best of all, I absolutely love that I can palm the wheel on the wood now. I never did before because I always feared that I would wear through the color on the leather (which seems more like rubber to me anyway?). My original wheel, with 120k, only started showing a little wear on the hump of the southeast sewing seam and just very mildly beginning on the northwest seam of it.
So my best advice to everyone out there, if you're looking for a Nav wheel, don't bother with the entire column. Just get the wheel. The dealer has confirmed that the Ex clock spring is for the Ex only, so the Nav one may not work. I haven't been able to look at an Ex with the redundant controls to see what the clock spring plug looks like though, since the plug is the only thing preventing it from working.
However, it's a good start to search for Nav columns, and then ask the place if they have the wheel available. Even though I paid almost exactly an average of what the wheels only are selling for on eBay, the column was listed for much less and he would include the wheel for $40. So maybe there are some nice $40 wheels out there? Also, make sure to ask for close up pictures of the wheel, because some of them are in bad shape. I remember looking at one with like 64k on it that looked amazing in the pictures, but when he took close ups, it really wasn't so nice after all.
Jon
Thats what I wanted to know. I know that they are different for some reason, but Im not putting mine into an airbag application, so if the airbag doesnt work, it doesnt matter haha
Long story short, we repaired the Navigator clock spring and used it. It has all worked great since except the radio buttons. I think that's because the radio I have in there is a replacement.
Just last Friday, I put the radio from the rollover in there, which is a factory Excursion six disk. I briefly connected the wire I had run to the plug before, and it didn't work. I must have the wrong wire now.
I'm on my phone right now, so I can't easily search to find that thread. If you can't find it, let me know and I'll find it.
Jon
Here's the link:
https://www.ford-trucks.com/forums/1...xs-how-to.html
Jon
Here's the link:
Jon
Thanks Jon, I am starting this weekend if the wheel gets here by friday.
