Need a new engine HELP Guys
Old Jan 28, 2011 | 01:21 PM
DYDF250's Avatar
DYDF250
The dealer has me over a barrel The # 3 cyl is scored They say i need a new engine
Here they r saying round the 12000
what am i going to do
HELP
Old Jan 28, 2011 | 02:09 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
That one could be rebuilt.... they didn't give you an estimate on that?
Did they say what caused the scored cylinder?
Old Jan 28, 2011 | 02:24 PM
DYDF250's Avatar
DYDF250
I asked an other dealer what that would entail still in the 5000 range and the work up to them finding the problem
The cyl is scored by too much fuel dumped into the chamber. EGR failed then the injector issue.
Help
Old Jan 28, 2011 | 03:03 PM
Zmann's Avatar
Zmann
cummins swap
Old Jan 28, 2011 | 05:40 PM
broncoformudv's Avatar
broncoformudv
$12,000 is a tough pill to swallow, I think at that point I would be looking for a wrecked Dodge and doing the cummings swap that Zmann mentioned. Then again I know how to turn a wrench and have that as an option without dropping the coin to have another person do the work. Either way a new engine or having your current engine repaired is not going to be cheap or done today. Good luck!
Old Jan 28, 2011 | 06:00 PM
ljutic ss's Avatar
ljutic ss
So what happens a few years down the road when all states will require emission inspection. What does the inspector do when he opens the hood and instead of a V8 Powerstroke there is a 6 cylinder engine? I have no idea, but it's something to think about.
Old Jan 28, 2011 | 06:05 PM
Young Gun's Avatar
Young Gun
Could you do a short block and reuse everything else?
Old Jan 28, 2011 | 06:08 PM
High Binder's Avatar
High Binder
That's a $15,000 swap.
Look DYD, you can get a new long block for $4000. Or you could yank the block you have and bore/sleeve for super cheap.And I would only do that IF they're not totally full of shet. At the very least take it to a second shop for a second opinion.
Old Jan 28, 2011 | 06:43 PM
DYDF250's Avatar
DYDF250
Hey thanks guys They r putting a sleave in, thats all i can do for now no $$, the only option cant afford, they discounting for me
Old Jan 28, 2011 | 07:05 PM
High Binder
Yep, like I said that's the cheapest option and most common.
Old Jan 28, 2011 | 07:18 PM
Zmann's Avatar
Zmann
the cummins swaps are legit but you have to use a same or newer year motor with all the same emissions that were mandated for that year
I just had 6k worth of work done on mine and if it was my dime I may have lit a match instead lol
Old Jan 28, 2011 | 08:11 PM
dieselgregg's Avatar
dieselgregg
yah that should fix it until another injector fails and you push the repeat button on the my luck sucks player!!! tick tick tick. My labor is free and I would have scrapped it!!
Old Jan 28, 2011 | 08:46 PM
cheezit's Avatar
cheezit
check price on a short block its around 3500 reuse the the rest of whats good. as long as there is no real amount of metal transfer anyway.
if there is your in a new game. hard to give advise of what to do with an engine thats not in front of me.
you can also look at the used engine options. figure about half the cost of new.
1979-Old-Blue
18
Jun 24, 2015 02:54 PM
broford1
16
Jul 28, 2011 05:27 PM
royallawnskc
30
Jan 6, 2007 03:28 PM
eviljarv
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Oct 8, 2006 08:19 PM
frank1
Jun 21, 2005 03:06 AM
