need a/c help
Old Feb 1, 2011 | 04:15 PM
ekm71f100's Avatar
ekm71f100
no i havent tried that, if it was the dimmer swtch wouldnt it do that all the time and not just when the brights are on?
Old Feb 1, 2011 | 04:38 PM
raj6938's Avatar
raj6938
not really. part of headlight power goes through the dimmer switch. when i chagned mine it was the original. a friend of mine suggested to change it. so through prosses of elemination. im now at a stand still. i just went through every wire harness under the hood and found no bad connections and did find that headlights on my truck are powered from both sides.
Old Feb 1, 2011 | 04:57 PM
ekm71f100's Avatar
ekm71f100
hmmm, so what else does that leave
Old Feb 1, 2011 | 05:05 PM
raj6938's Avatar
raj6938
im not sure yet . waiting for other respones from others on the system.
Old Feb 1, 2011 | 06:51 PM
zenmaster's Avatar
zenmaster
raj6938 and ekm71f100,
Try cleaning the connections as Orich says. If that doesn't solve the problem, and you've already checked out the switch - try this:
Whiter Whites, Brighter Brights .: Articles
The oem wiring one these trucks is marginal from the factory. After 30 or 40 years of wear and tear(and numerous owners "fixing" the wiring), you get problems.
The above article is worth a look in any case.
Cheers,
John
Old Feb 1, 2011 | 07:03 PM
ekm71f100's Avatar
ekm71f100
that article is very helpfull, that looks like this weekends project
Old Feb 1, 2011 | 07:57 PM
orich's Avatar
orich
since I've had my truck. I replaced 2 head light switches 1. H/L beam switch
Cleaned every front and rear light socket a few times to keep my lights in working order..
orich
Old Feb 1, 2011 | 10:11 PM
TNTRUCKS's Avatar
TNTRUCKS
I was having the same problem on my 67 with the lights flickering and turning off, then on at will. I don't know how or why but it ended up being my high beam floor switch. I changed it a month ago and no problems yet.
Old Feb 2, 2011 | 11:11 AM
raj6938's Avatar
raj6938
Question intrament cluster.
has anyone found a company that makes a replacement for the electrical part on the back. mine is starting to seperate and i will need to relace it at some point.
Old Feb 2, 2011 | 11:20 AM
orich's Avatar
orich
Which part H/Low beam switch ? LMC or NPD, has many even auto zone has some. EBay vendors...
orich
Old Feb 2, 2011 | 11:53 AM
raj6938's Avatar
raj6938
hi/low beam
pushbutton floor switch below e break
Old Feb 2, 2011 | 01:43 PM
TigerDan's Avatar
TigerDan
It's a very universal item, used in one form or another on many vehicles up till about the 1980s. You should be able to walk into any auto parts store and buy one right off the shelf.
Old Feb 2, 2011 | 04:46 PM
  #28
ekm71f100's Avatar
ekm71f100
yup, you sure can, picked one up today for 5.99+tax
Old Feb 3, 2011 | 07:54 PM
  #29
raj6938's Avatar
raj6938
Smile head light flicker
thanks tiger dan. i pulled apart all my connections and reasembeled. so far so good.
