HELP
Old Jan 27, 2011 | 06:18 PM
Firstonraceday2's Avatar
Firstonraceday2
HELP
Trying to identify my top loader,
date tag HEF CW 048652
main case C5AR 7006-B
tail shaft C4DR-7A040-B
any help or info would be great
thanks
Old Jan 27, 2011 | 06:37 PM
Gary Atsma's Avatar
Gary Atsma
You are in the wrong forum (or even website). This forum is for 2009-on-up F-150 pickups, and last I checked, NONE of them were available with top-loader 4-speed trannies. Try to find the correct forum or website. You're in the wrong spot.
Old Jan 28, 2011 | 09:15 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved to the Transmission forum. You might also want to ask in the 1964 or 1965 years-specific truck forum, because those parts numbers are '64 and '65 (and up) part numbers.
Old Jan 28, 2011 | 10:12 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/1...smissions.html Look at the post by 85e in this link to identify your trans.
Old Jan 28, 2011 | 01:22 PM
Firstonraceday2
Smile
Thanks Krewat AND Lazyk, I'll check the info out. GARY open your mind knowledge can be found every where, you just need to look and listen.
Old Jan 28, 2011 | 01:52 PM
85e150's Avatar
85e150
thanks
Your toploader, it's from a car, and is a 3 speed, right?
It's a HEF CW..., from a 289 Mustang. Had one myself. Good shifting trans with a Hurst shifter on it.
ID chart here:
3 Speed ID Chart
Old Jan 28, 2011 | 06:02 PM
Gary Atsma's Avatar
Gary Atsma
Very good advice, which I've used quite often. By being open-minded, I've always sought out the CORRECT source for my info. Putting your post where you did is NOT an example of being open-minded. All I did was correct a misdirection. Can you be open-minded enough to handle that?
silverbullet6oh
Mar 31, 2020 07:45 PM
shortride
Jun 1, 2017 08:13 AM
Hazmat6750
Feb 24, 2016 07:54 PM
JWA
Oct 18, 2015 10:07 AM
rexx
13
Dec 12, 2002 04:17 PM
