help - choke not right?
Old Mar 9, 2003 | 01:57 PM
troy h.'s Avatar
troy h.
Question help - choke not right?
i can fix about anything but a carburator, i have a carter 1 barrel on a 300 cu in. i have power coming out of the electric choke wire, but it does not seem to affect the choke when hooked up. i have had to rotate the choke "off" in order for smooth running, but cold mornings starting is a bear. i cannot get the cold "high idle" to engage either. i need some good carb advice.
Old Mar 9, 2003 | 07:32 PM
Mike W's Avatar
Mike W
The choke heater coil may be open. You could check it with an ohmeter or take it off and see if the spring moves when you hook up power.
