I changed my lift pump yesterday after noon took a look at it and thought 30 minutes or so and back in business. Well it was more like 2 hours ridgid line was rounded off and so on, anyway when I wraped it up it was just getting dark. She started up fine but now the tach moves a little when the engine is cranking but lays at 0 when running and when shifted into drive it doesnt engage right. Reverse is fine though, wtf did i unhook?
the truck is a 93 f250 2wd auto 7.3 idi na
Sonds like a bad joke my kids would play while i go in for a beer or something and disconect my trans and tach! but i know i had to have hit something under. Any ideas?
Being a '93 it should have an E4OD in it, which relies on the tach sensor for inputs. Up top, to the driver's side of the oil filler, is the tach sensor. It's pretty common for the wires to get 'bare' where they enter the sensor, and the start causing issues. I suspect what has happened is at some point you must have disturbed a wire or something that leads to the sensor.
If you end up having to replace that sensor, it's a dealer only item.
It may also be in the wiring between the engine and passenger side fender, again, depending on how you accessed the lift pump to replace it. The tach sensor wires travel through there, IIRC, they are in the bundle along with the alternator wires.
thats right where i pulled the pump up through. i had to leave the ridgid line on the pump and disconect it from the filter houseing finessing at this point was thrown out the window. I will go out and trace those wires.
Thanks for the insite and fast reply
I agree with greywynd, sounds like something got messed up with the harness for the tach sender. Or it's just a pure coincidence, and the sender decided to die on you at that exact moment - weirder things have happened, so it's not out of question. The important thing is to not drive the truck before you locate the problem and rectify it, because no tach means failure-management mode for the PCM, resulting in full line pressure which can do some internal damage (IIRC one of the clutch drums don't like it, or something like that).
Greywydn when you say "Up top, to the driver's side of the oil filler, is the tach sensor." Do you mean oil fill? I see too wires and a sensor there that come from the same wire loom as the alt wires?
those wires are fine and should have not ben disturbed but i guess the sensor could have just gone or something. I did disconect the starter solinoid wires and positive batery terminals to gain some room when working the pump out maby something shorted in the process?
There is a test, you measure resistance between the two wires, first away from any metal and then right against a ferrous metal surface. Don't remember the numbers you're supposed to get, but I do remember that my tach sender passe said test and still didn't work like it should...
I would double check the wires from the sensor to the inner fender, just too much coincidence that it happened at the same time. Maybe they got pulled a bit one way or another, disturbing a connection at some point. I know there's a connector at the sensor, can't recall if there's another one between there and the passenger fender or not.
the od light is not on, pushing the od button does nothing eather.
I cleaned the plug conections and checked the fueses under hood and in cab.
a test with a multimeter set on ac voltage conected to the sensor showed an increase of voltage as i rev the engine. sensor should be fine? right?
has to be a bad conection some where else. any ideas of what or where to look next?
have you checked plug in at transmission? if so check plug in at tcm that is at driverside firewall rectangle shape with 10mm bolt through the center of it looks like 50 wires coming out of it let me think about it a while went throuhg all of this awhile back but i had to replace the tcm.
