99 F250 4X4 issues
Old Jan 27, 2011 | 10:05 AM
mattmang's Avatar
mattmang
99 F250 4X4 issues
I have a 99 250 and my electric 4wheeldrive doesnt like to engage sometimes. my 4 high will work here and there and my 4 low idk if it works it doesnt light up as 4 low.
also my air only works on defrost.
and finally today a clicking noise happens when i turn the key to let the glow plugs warm up.
any help would be awesome!
Old Jan 27, 2011 | 10:34 AM
woodnthings's Avatar
woodnthings
Welcome!
Your hubs are operated by vacuum and so are the heater controls. You most likely have a vacuum leak or no vacuum, so you will need to determine why. You can usually separate the systems and using a vacuum pump to find leaks.
If you have a clicking noise when you turn the ignition on, you more than likely have a battery voltage issue. When the solenoids start randomly clicking it is usually from low voltage or bad connections. Check your batteries for voltage and individually with a load test. While you are there inspect the terminals for corrosion.
Old Jan 27, 2011 | 11:18 AM
mattmang's Avatar
mattmang
I figured it was a vacuum leak but my fan is also only working on high i will check for leaks thou.
as far as my 4 wheel drive, could it possibly be the relay/ solenoid?
Old Jan 27, 2011 | 12:39 PM
woodnthings
It could be a bunch of things. If you have a vacuum problem your hubs will not engage.
As far as not going into 4 Low, does that light illuminate on the dash when you first turn the key on? Could be just a burnt out bulb.
Old Jan 27, 2011 | 01:04 PM
woodnthings
Old Jan 27, 2011 | 04:16 PM
mattmang's Avatar
mattmang
thank you for your help i put in new vacuum lines and the 4 wheel drive works good now. in doin that i found out that the clicking noise i was talking about earlier was comming from what i think is my vacuum motor/pump. and my defrost is still the only thing working im guessing it has something to do with the actual fan?
