Vent cowl off
Old Jan 27, 2011 | 07:37 PM
ctubutis's Avatar
ctubutis
Originally Posted by LARIAT 85
...and the 1987 - 1991 "pin hole" cowl is a direct replacement for the 1980 - 1986 "slotted" cowl. Even though it will still fit, the 1992 - 1996 cowl is slightly different.
Yes, thank you for the dates! I had forgotten the exact years, I knew that info about two
years ago when I got one of those pinhole things for my own truck.
Originally Posted by Fordzilla80
Since people always love pictures....
This second pic was taken before I aligned the panel, so that's why the lines on the hood and the cowl don't match up. I didn't paint mine because the color was close enough that it's barely noticeable unless you look for it.
Shaun, I'm assuming that's an 87-91 panel, correct? If Lariat's dates are correct (and I
assume they are) the 92-96 ones will fit BUT they don't have the raised (lowered)
dual-height crease that matches up to the crease in the hood. Also, the wiper fluid
sprayers are different, there are two with one located on each side instead of one in the
middle with two jets.
Originally Posted by Anafiel
What did I do wrong?
Not disconnect the antenna from the radio?
Old Jan 27, 2011 | 07:50 PM
Anafiel's Avatar
Anafiel
So I'm then to assume I need to pull the cowl with the antenna cable attached?
Old Jan 27, 2011 | 07:53 PM
Fordzilla80's Avatar
Fordzilla80
Yes, my panel is from an 88. And Lariat has the dates correct, as do you with the 92-96 panel description.
Anafiel, the antenna wire just pulls out from the antenna base.
Old Jan 27, 2011 | 07:59 PM
Anafiel's Avatar
Anafiel
Got it! I'll try that again this weekend. I wanted to do the hardware cloth trick, as there are no donor options at the jy just now.
Old Jan 27, 2011 | 08:11 PM
ctubutis's Avatar
ctubutis
I've never gotten that to work, maybe I just wasn't pulling hard enough (for fear of
breaking something) or mine is maybe different somehow.
Old Jan 28, 2011 | 02:08 AM
Redneck1465's Avatar
Redneck1465
You just have to pull the antenna off of the antenna cable that runs to your radio.
Old Jan 28, 2011 | 02:27 AM
glovemeister's Avatar
glovemeister
I pulled out the screws today and the wipers. First time removing the entire assembly it took my about 20 minutes but none the less it was a learning experience. After that I need to open the hood, pull the antenna cable, un screw some fasteners, and then pull it off and go to work? What would you guys suggest for an approximate angle for the hood to pull the cowl off?
Old Jan 28, 2011 | 04:07 PM
Fordzilla80
Honestly, I scratched the hell out of my cowl panel when I left the hood on. What you can do though is loosen up the bolts on the hood hinges. When you do that, pull the hood up towards the sky, and then re-tighten the bolts. This gains you a little bit of wiggle room. Just be sure to take a marker or scribe and mark exactly where the hinges sat because re-aligning the hood is a pain.
As for the screws, there's about 8 or so on the front of the cow panel, and about 3 or 4 on top. The screws on top are hard to see, you have to get up above the truck to see them. Make sure you get these out or else you're gonna damage the thin mounting brackets. When you pull the antenna cable, if it doesn't come out with a direct pull, twist it to loosen it up and then try again.
Old Jan 28, 2011 | 04:36 PM
Redneck1465
Maybe I just keep getting lucky but I never had any issues with scratching the cowl or the hood. But if your not sure if you can get it off with scratching it it probably wouldnt be a bad idea to remove the hood.
Old Jan 28, 2011 | 06:41 PM
Fordzilla80
There's a possibility my hood is messed up, as I can never get it to align right. And it sits kinda high in the center as if it's bowed. May or may not be my problem.
abe
Jul 2, 2021 12:21 PM
Nicmike
Nov 26, 2019 09:46 PM
nothercrash
15
May 14, 2018 01:10 PM
Torky2
1978 - 1996 Big Bronco
Nov 16, 2016 11:21 PM
bigredtruck
Jun 28, 2016 11:17 AM
