Sponsored by: Real Truck
Engine missfire
Old Jan 26, 2011 | 09:58 PM
brentaleclaire's Avatar
brentaleclaire
Engine missfire
I recently developed an engine miss on my 99 super duty with a 5.4 liter engine.No check engine engine lights came on, but I was able to pick up a code using a portable scan tool. The scanner showed a miss on#8 cylinder.I removed the old plug ,which didn't look bad. I put a new plug and coil pack in,but still have the miss.I pulled the coil wire and hooked to a new plug and grounded it,and could see a good spark. Could the scan tool be giving me the wrong code or cylinder?
Old Jan 26, 2011 | 10:36 PM
superdutybob2122's Avatar
superdutybob2122
On my 5.4 I've had the engine miss one time but had two bad coil packs, #6 and #8. I would try #6 next and if that doesn't work keep roatating coils until you find it
motorcycleemporium
Sep 2, 2010 07:31 PM
JRT32615
1997 - 2003 F150
Jan 20, 2007 08:14 PM
baha_49
Dec 8, 2004 05:43 PM
