Choke/idle question
Old Jan 26, 2011 | 01:11 PM
phurst's Avatar
phurst
Choke/idle question
I have what may be a stupid question to someone more familliar with carbed vehicles, but i feel compelled to ask it anyway
Now that it's good and cold outside, there are times I would like to start the truck and let it warm up. I get in, mash the gas to set the choke, and it starts up fine. With the choke engaged, it idles around 1200RPM. As the engine warms, and the choke opens, the RMS rise. Is there a point where the RPMs will/should drop back down to normal by itself? If I tap the gas, it drops down to 800-900 and idles just like it always does, but if i don't tap the gas, they just keep climbing. So far, I have seen them go up to 2500RPM. I didn't have the nerve to see how high they would go without intervention, so I hit the gas. Is this normal? I'd love to be able to allow it to warm unattended, but not if the engine is going to rev itself to death.
Old Jan 26, 2011 | 01:27 PM
glovemeister's Avatar
glovemeister
Do you have an electric choke? If so you may need to adjust it so it comes on earlier.I think that there are three bolts, and its clockwise to open earlier, ccw to open later.
Old Jan 26, 2011 | 03:14 PM
Old Hickory's Avatar
Old Hickory
The idle will normally rise when the fast idle of the choke is engaged as the engine warms
up it runs more efficiently. The idle won't go up anymore after it reaches a certain point.
I think 2500 rpms would be about the limit depending on how your fast idle adjustment
is set.
Old Jan 26, 2011 | 03:19 PM
phurst's Avatar
phurst
Would adjusting the fast idle screw affect anything besides this behavior? I'd really prefer it stick around 2k, but I don't know what else the fast idle adjustment does, if anything.
Yes, it's an electric choke. It's adjusted so that it's just closed when it's cold out. I don't think how early or late it opens has any effect on how high the idle goes, just how quickly the revs rise.
Old Jan 26, 2011 | 05:35 PM
Old Hickory
You can back off the screw that hits the fast idle cam and it will slow down the idle
speed and it won't have any effect on how fast the choke opens. When the choke
plate starts to open it takes the spring pressure off of the cam so when you hit the
throttle it releases the fast idle cam and the engine idles normally if it is warmed up
enough. The fast idle cam usually has at least two steps in it. This means you can
blip the throttle after it has started but before it is completely warmed up and the
the fast idle screw will engage the second step on the cam which will let it idle at a
lower speed which will let the engine warm up at a more moderate idle speed.
Old Jan 26, 2011 | 05:59 PM
phurst's Avatar
phurst
Great info, thanks. I'll fiddle with it this weekend.
swampthang
Apr 9, 2020 12:29 PM
Heesman
Sep 5, 2014 03:00 PM
granny_rocket
Sep 30, 2013 08:10 AM
granny_rocket
Dec 23, 2012 08:15 PM
Nathan Plemons
Jun 30, 2009 06:44 AM
