Help with trans.
Old Jan 26, 2011 | 12:15 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Help with trans.
Ok so on my 04 6.0 last night the check engine light came on and apparently the check gauge light came on and he said it felt like it was kicking in and out of tow haul and the tow haul light may or my not have been flashing because he tried to take it out of tow haul. The codes I got were
P0713
P0710
P0700 comes back when I clear codes.
P0500
SCP J185J
I went out and drove the **** out of it and i got the trans fluid temp to 195.
Any one know what is going on here? Looked at the trans fluid level and it's perfect and does not smell burnt. Also the trans does not miss a beat. What do u guys run normally at for trans fluid temp?
Old Jan 26, 2011 | 12:47 PM
utjer's Avatar
utjer
I dont know what your issue could be buy my trans will run in the range of 140's to low 150's.
Old Jan 26, 2011 | 06:58 PM
adambomb's Avatar
adambomb
hopefully if Trans Guru Mark K has any insight he will see your thread. when fully warmed up normal driving 160-165 is about where my truck is with custom tunes and 35 inch tires. 195 isn't over the limit so i don't think it was because of the trans temp. and also 130-140 i don't even think the thermostat opens at that low. Good Luck
Firetrout
Aug 4, 2013 10:16 PM
Piolet
Apr 18, 2012 10:34 PM
FI460
Apr 9, 2011 11:53 AM
SOB Racing
Mar 16, 2009 03:20 PM
03KingRanchF250
Mar 31, 2007 01:25 PM
