Maybe this will help somebody.....
Old Jan 25, 2011 | 11:35 PM
SLUF681's Avatar
SLUF681
Bought my truck Oct. 31 of 2010. Since Day 1, the temp never went above bottom line of "normal". Truck heated up quickly, but would not hold temp at idle or when you let off the accelerator. I kinda thought that the thermostat was bad, but since it warmed up quickly, it had to be working, right? Next thing was I assumed the idiot gauge must be messed up or the sending unit was bad.
Decided to change the thermostat first and then move on to the sending unit before buying an aftermarket gauge. Glad I did. The thermostat fixed it. Temp now runs in the mid "normal" range and the heater, well, I didn't know I had a heater before!
Anyway, Just thought I would share the info since I haven't ever had a thermostat fail like that. Put it in water on the stove and checked it. It was opening at around 140* and closing back down at around 110*.
Old Jan 25, 2011 | 11:45 PM
BigAlsPSD's Avatar
BigAlsPSD
Great thought, in case someone needs to reference it. "Knowledge and Experience are Power"
Old Jan 26, 2011 | 08:03 AM
Kwikkordead's Avatar
Kwikkordead
I've had a number of thermostats stick open on customer's cars at work.
Old Jan 26, 2011 | 08:23 AM
robs01f250's Avatar
robs01f250
thanks for the info. This info is much appreciated around here
Old Jan 26, 2011 | 12:28 PM
bulla's Avatar
bulla
Yes, thanks and glad to hear you figured it out without having to chase rabbits!
Old Jan 26, 2011 | 12:47 PM
PaysonPSD's Avatar
PaysonPSD
It would be interesting to know if you get a small increase in MPG running warmer. EOT would be higher and fueling and timing would be different. I'm curious, so let us know if there is a difference. Might be something else to think about if fuel mileage goes down.
Old Jan 26, 2011 | 01:05 PM
SLUF681's Avatar
SLUF681
I changed the air filter at the same time. It was quite dirty. I did see a 2mpg increase but as bad as the air filter was I would have to accredit the increase to that. It was the first time I had checked the air filter since buying the truck. I've never seen a filter that bad.
Old Jan 26, 2011 | 02:14 PM
PaysonPSD's Avatar
PaysonPSD
That certainly skews the MPG results. But thanks for mentioning that so I won't be watching for any results.
Old Jan 26, 2011 | 03:09 PM
JonathanN's Avatar
JonathanN
The motor not warming up also keeps the PCM from seeing warm enough temperatures to back the timing off from the "cold advance" that it does when the motor is cold. Mine wouldn't warm up much either... my MPG's sucked and the truck wouldn't warm up like it used to. It was noisy and had a lack of power... now it's quiet and spunky again!
Old Jan 26, 2011 | 04:18 PM
PaysonPSD's Avatar
PaysonPSD
Thanks for chiming in with this Jon.
A bad EOT sensor will make the truck run bad as well, or at least not as efficiently.
