ccv problem
Old Jan 25, 2011 | 03:39 PM
jp1gt's Avatar
jp1gt
ccv problem
I am having one those vortex situations. I had a intercooler hose leaking oil. I got some info about installing the ccv tube. It worked well, but my wife pulled her horse trailer, about 6K lbs. There was oil all over the underside of the truck. I cleaned it out and it does not leak now (no load) I am thinking it came from the rear main seal, under load. I understand that the ccv hooked up to the intake creates a negative pressure on the crankcase. Anyone else experience this?
Old Jan 25, 2011 | 04:05 PM
pjwoolw's Avatar
pjwoolw
Where is the CCV plumbed?
Old Jan 25, 2011 | 04:14 PM
Talyn's Avatar
Talyn
The CCV hooked into the intake is supposed to create a vacuum, but it does a poor job.
Venting to atmo under the truck shouldn't produce any oil unless you just ran the hose strait down from the doghouse.
Make sure you run the hose up and over the break booster so oil cannot get down the tube. And make sure its 3/4 inch hose otherwise you'll create back pressure in the system. I did that by oopsies using 3/8's line which I figured would be enough. Didn't realize how much that thing breaths.
Hope this helps. =)
Old Jan 25, 2011 | 05:37 PM
jp1gt's Avatar
jp1gt
I understand what you are saying. I ran the hose up and then down through the round coils in the brake lines running down the front of the firewall, but the hose is hanging down next to the front drive shaft and IS pointing kind of forward and that could put a positive pressure on the crankcase and cause a rear main to leak at high speed! She was hitting at least 60 mph.I will reposition the hose and drive it again!
Old Jan 25, 2011 | 06:41 PM
nelstone74's Avatar
nelstone74
I don't think that the hose was bing pressurized from the position of the hose. The hose is a small target for the wind.
Old Jan 25, 2011 | 07:39 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Is the valley of the motor dry or are there oil there? The rear main seal is very rare that leaks, and seems that there are a lot oil all over the underside of the truck, I dont think that a IC boot could leak that way, that should be caused by another source of oil: HPOP?.
Old Jan 25, 2011 | 09:04 PM
Talyn's Avatar
Talyn
DC's would be higher which if there was an HPOP leak, it could be that.
Your theory on the tube for the CCV isn't off, size or not, you could create positive pressure if the hose was positioned just right at just the right angle to the attack of the wind, but that is highly doubtfull.
The other big oil killer is the EBPV actuator arm.
Old Jan 25, 2011 | 09:13 PM
jp1gt's Avatar
jp1gt
I have cleaned the valley, and in the bell housing and can not see any more leak after I re-positioned the tube. If I did not say this before, it all started after I took the tube off the turbo intake and added the tube. I have to make a 100 mile run tomorrow, I will post the results.
Old Jan 25, 2011 | 09:32 PM
Talyn's Avatar
Talyn
Where oil is at in the valley is the biggest sign of where its coming from.
You wont (well shouldn't really) have oil from the turbo up by the hpop.
Old Jan 26, 2011 | 06:24 AM
FARM69's Avatar
FARM69
What about the dog house the the CCV hose comes off? Those orings are junk.
Old Jan 26, 2011 | 10:15 AM
MagKarl's Avatar
MagKarl
Many folks run their CCV hoses straight down from the doghouse with little to no oily mess dripping on the truck belly or driveway. The end of my hose is oily from vapor, but it does not drip. I'd do as Farm suggested and check those o-rings for the doghouse. While the doghouse is off I'd rinse it out with solvent. The steel wool in the doghouse might be totally soaked with oil and maybe that is blowing down the hose. Clean it out and then maybe rig up a temporary catch can to see if you are really getting a lot of oil out the CCV hose and go from there.
Old Jan 26, 2011 | 10:39 AM
jp1gt's Avatar
jp1gt
The oil is NOTcoming out of the ccv hose, just vapor. I cleaned the valley and inside the bellhousing. I can not get it to leak now, but it dumped 2 qts of oil from somewhere when my wife pulled her horse trailer 30 miles. I replaced the fuel pump lines to the back of the heads last year because the idiot mechanic at the dealership that installed the engine could not tighten down the fuel pump properly and it broke one of the lines. I had to pull the turbo to do this, but I don't see any leaks there. One question. On a gas engine, there is a ccv and a pcv valve to lower the crankcase pressure, it there a pcv valve on the 7.3? At idle there is a good amount of vapor coming out and actual pressure. The engine has 30K on it and uses no oil.
Old Jan 26, 2011 | 10:51 AM
Talyn's Avatar
Talyn
no PCV.
the pressure coming back is blowby past the rings which is a normal thing for diesels.
High compression and violent reactions in the chamber cause it.
If you lost oil I bet you lost it from the Hpop check valve or the EBPV.
Talyn's Avatar
Talyn
no PCV.
Old Jan 26, 2011 | 10:57 AM
jp1gt's Avatar
jp1gt
where are the Hpop check valve and the EBPV. There was oil everywhere, now it is clean and I will be checking on my run today.
