Sponsored by: Real Truck
Gears
Old Jan 25, 2011 | 01:30 PM
209ford's Avatar
209ford
Gears
Im new to this and I need help I have a 2004 f250crewcab 5.4 with 8 inch lift and 37 inch tires and Im not sure what kind of gears do I need. Some people told me that 456, what do you guys think? Thanks for the help. I want a quick acceleration because the 5.4 don't help me. Specially if it's stock.
Old Jan 25, 2011 | 03:07 PM
Lubbockguy1979's Avatar
Lubbockguy1979
I would say 4.56 minimum and probably 5.13 I would also look at a sct tuner and tunes from 5 star or the gryphoon from power hungry perfirmance. That should make a night and day difference alone.
Old Jan 25, 2011 | 03:38 PM
mwsF250's Avatar
mwsF250
I would go 5.13
4.88 as second choice.
Old Jan 25, 2011 | 04:19 PM
redford's Avatar
redford
FTE Leadership Emeritus
209ford, welcome to FTE.
Don't guess. We can figure out what you need using the automotive calculators on this site.
Automotive Calculators offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com
Your stock tires were around 32 inches, give or take. I will assume you have the ubiquitous 3.73 gears in your truck now. Damn near everyone does. If not, plug in your own numbers.
Given those numbers, a 4.3128125 gearing is required to return to effective stock gearing. 4.30 would be the closest stock ratio.
Old Jan 25, 2011 | 05:29 PM
Lubbockguy1979
factor in the stellar stock performance of the 5.4, the aerodynamic disadvantage and the weight of the lift and tires and you will be unhappy with 4.30's..
4.56 would be the minimum
Old Jan 25, 2011 | 05:50 PM
REXHOUND's Avatar
REXHOUND
5:13 min if it were me
Old Jan 25, 2011 | 06:22 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Originally Posted by mwsF250
I would go 5.13
^^^this^^^..
dont even consider anything lower then 4:88's...
Old Jan 25, 2011 | 10:23 PM
209ford's Avatar
209ford
I just went to a shop to ask them to. and the guy said that he recommends me the 4.88. And he gave me a price of $1480 it's that a fair price? I still need to go check around other shops but it's between the 4.88 and 5.13. I really don't drive this truck often just on the weekends. So not really concerned about mpg.
Old Jan 26, 2011 | 12:18 AM
lariat79sc's Avatar
lariat79sc
Well we both know the 5.4 is an extremely reliable engine that can take RPMs. Years ago a friend of mine had a 97 Ram 360v8 with 37" tires and the 5.13 gears. It moved out nice and it still could go down the highway. However with better torque and more usable RPMs I'd probably be moderate with the 4.88s myself. Granted his was a Dodge, but he broke drive train and suspension parts all the time.
Old Jan 26, 2011 | 09:30 AM
dclack's Avatar
dclack
If you have the Dana 60 front with 3.73 gears, I'll buy them off you.
Old Jan 26, 2011 | 05:10 PM
209ford's Avatar
209ford
Yes I do have does, but my friend told me not to long ago that he knew someone that would buy them too. But I'll check and let you know.
