Help! I'm in 4WD and can't get out
I have tried everything I can think of... driving in revs., pounding the dash, kicking the tires... I can't get the truck out of 4wheel low! I was doing some work around the yard and was muddy from all the snow melting... locked her in to 4wheel low, did my work, then couldnt get it out of 4wheel!! I cant get into 4 wheel high either... it's stuck in low!!!
PLEASE help
PLEASE help
Had the same thing happen to me 4hrs from home out 5 miles on a lake , not a good feeling especially which a bunch of gm and dodge guys.I finally tryed shutting off the motor and put it i N and it just popped right out.When I got home I tryed it again ,same thing, what I did find though is if you shift the trans from R to N and push the T case shifter at the same time it will come out or D to N works too. Good luck
