Locating Oxygen Sensor Signal Wire - HELP!
Jan 25, 2011 | 02:44 AM
Need help locating my o2 sensor signal wire in the pcm. Anyone know which it is? PCM is in the drivers footwell along fender, correct?
Thanks!
Jan 25, 2011 | 07:37 AM
Which O2 sensor wire? There are two
The PCM is located on the driver's side kick panel. Not sure the 2002 is going to have the same color wires as my 2001, but here's the ones for mine:
Crap, can't find my Ford service manual CD. I'll look around for it - but in the mean time, anyone else have a 2002 EVTM handy?
Jan 25, 2011 | 11:12 AM
Any o2 is good I'm just tapping my air fuel gauge and everyone says tap directly to the PCM o2 signal wire.
Jan 25, 2011 | 02:27 PM
It's easier to tap into it on the engine side of the firewall. Just trace the harness up from the 02 sensor and splice in above the connector.
Jan 25, 2011 | 07:44 PM
My 2003 wiring diagram shows (If I am reading correctly ) :
From heated oxygen sensor 11 :
wire 1 (Gray/LtBlue) goes to PCM -terminal 60 (HEGO 11) -same color wire
wire 2 (Red/White) goes to PCM terminal 93 (HEGO11 ) -same color
Heated Oxygen sensor 21:
Wire 1 (Red/Black) goes to PCM terminal 87 (HEGO21)
Wire2 (Yellow/Lt Blue) goes to PCM terminal 94 (HEGO21)
There is also an additional California Spec :
Heated Oxygen 12 (California ) :
Only one wire (White/Black) goes to PCM terminal 95 (HEGO 12).
Hope this helps.
Ken
MADMECHANIC1991
1997 - 2003 F150
Feb 8, 2025 04:35 AM
corksil
52
Aug 9, 2021 03:28 PM
phatmarcus
Jul 27, 2021 10:52 PM
autotec
16
Apr 29, 2016 08:28 AM
artieb
Feb 2, 2012 12:59 PM
1996 ,
2002 ,
2008 ,
color ,
diagram ,
explorer ,
f150 ,
f250 ,
o2 ,
oxigen ,
oxygen ,
sensor ,
signal ,
sport ,
trac ,
wire
