3.55 ls? so i have a limited slip in my rear? thats like a locker? and is 3.55 matched right with 235 85 16? if not what should i be running? seems like its just reving high wile doing 65 in o/d...
Limited Slip transfers power to the tire with the most amount of resistance. This equals better traction. Limited Slip is much friendlier than any locker. It's nice to have!
well i have a leaking exaust... nice and loud.. needs oil change. tune up. tps. hoping to mabye achieve 11+ after all that... then when more money allows i want to change diffs out with royal purple and change trans and transfer case too.. then i hope ill be around 14. id be happy with that...more then happy. be happy with another 50hp too lol...hardle has any top end grunt...
doesnt...has 144000 on the clock. itll git up and go but ill count in my head from a dead stop to needle pegged past 85pmg and its like around 20 seconds. now if im crusing at like 55 in 5th or o/d and i stomp on it to try and pass someone its non existant...i have to down into 4th... mabye bc its an od gear but i feel like it should git outa its own way. it doesnt.
No its not. OD is for crusing. if you read the owners manual i believe it even states you need to downshift out of OD if you wish to pass. OD is for maintaining speed, not gaining it.
well thats what i usually have to do lol... so it aint my truck then...
i wish my f350 with the 351 had a little bit more, you stomp on it from dead start it goes but wont set you back in the seat. of course ive got to move 6500 pounds and since its winter the hubs are locked, so theres more weight to turn. Back to mpgs, im getting 8 mpg on average, i get like 5-6 loaded. I would be happy with like 11-12, i dont think 33-12.5 tires help any eather, maybe if i go back down to 235-85's i would see some improvement
anytime throttle exceeds a certain point or below a set speed trans automatically disengages OD.. If it does not you have an issue, so yes if you are somehow "locked" in OD acceleration will be sluggish. Switch is there for manually disengaging/disabling OD in cases of towing or steep inclines..
