Aerostar Ford Aerostar
aerostar reading
Old Jan 24, 2011 | 09:20 PM
bertha66's Avatar
bertha66
aerostar reading
hey i had my aerostar put on a engine computer. It said that my cylinder were not amcthed. What does this mean. also throttle not snapped can someone help me so i can fix it. not bad for a 21 year old car.
Old Jan 24, 2011 | 11:24 PM
KhanTyranitar's Avatar
KhanTyranitar
Cylinder balance tests measure the performance of each cylinder to detect misfires. It means that one or more cylinders is not firing properly. This does not narrow down the cause though, just which cylinders are involved. I would remove and inspect the plugs and see if they can tell you more of the story.
Old Jan 28, 2011 | 08:51 AM
bertha66's Avatar
bertha66
Thanks, I will check those out this weekend when I change out the heat senser.
Old Jan 31, 2011 | 10:13 AM
bertha66's Avatar
bertha66
Changed out the heat senser and checked out the plugs, plugs looked good, with only less than 10k miles on them. Running good now, will have to put it on a computer again to see what comes up.
Old Jan 31, 2011 | 10:54 AM
99f350sd's Avatar
99f350sd
You mean the coolant temp sensor?
Old Jan 31, 2011 | 11:56 AM
bertha66's Avatar
bertha66
Yes, it was the coolant senser.
