Backfire
Old Mar 9, 2003 | 02:03 AM
SumoBronco's Avatar
SumoBronco
Backfire
Anybody want to give the new guy some help?
I have a full-size '86 Bronco with 4.9L 300 I6 w/ 1bbl carb.
Last fall, it starts backfiring, right before hunting season. I took it to a local shop, and the guy says its the thermactor valve. As a temporary fix, he takes off the belt that runs the thermactor. It ran without backfiring, but gave off really dirty exhaust and started stalling out at idle.
Finally got the part put in, but it starts backfiring again. I bring it back to the shop and they adjust the carb. He says it is still running too rich, but he can't adjust any lower. Also says carb should be replaced ASAP. It is still backfiring, when decelerating in gear, or even just going downhill slowly in gear.
My plan is to rebuild the carb (will be my first time for this) because I think this might be the problem. Any suggestions on things I might have missed that would cause this problem?
Old Mar 9, 2003 | 03:45 AM
79 posi's Avatar
79 posi
Backfire
Totally a guess here, but could timing be an issue?
Old Mar 9, 2003 | 01:22 PM
Vampiro's Avatar
Vampiro
Backfire
if it backfires the timing isnt set right. time it first
Old Mar 13, 2003 | 02:24 PM
SumoBronco's Avatar
SumoBronco
Backfire
Thanks! I'll start with the timing and save the carb for later.
Old Mar 18, 2003 | 08:00 PM
kcw12's Avatar
kcw12
Backfire
Speakin of timing. where are the marks for the timing and would timing make valves clatter.
Old Mar 19, 2003 | 02:50 AM
GeneStoner's Avatar
GeneStoner
Backfire
As you are looking down to your engine, the timing marks are next to your harmonic balancer on the left. NOT, on the cover of your timing chain.
Old Mar 22, 2003 | 03:03 PM
cypress_303's Avatar
cypress_303
Backfire
If your six is equipped with the polution control recirculator pump, and all the junk that goes with it, that can be the cause of back firing, that was cause of mine, every time i'd grab 3rd it sound like i was doin a drive by shooting. If it's the kind where the whole polution control starts out right above each exaust port, (kinda looks like old school fuel injection) the rail that all the ports feed into can wear and rust out due the fact it's thin material, you can pull all that junk right out, pump included and plug the holes with a stard NPT pipe or hydraulic fitting, I think it's 3/8 NPT but not totally sure any more it's been a while since dealin with that delema. Hope this pertains to you in any way and maybe helps.
~Ben
ColtonMullis
Jan 20, 2014 03:53 PM
lawdogg_78
Feb 23, 2011 12:51 AM
gearhed1971
Apr 8, 2007 08:10 AM
1yamman350
Apr 18, 2006 03:08 PM
steve005
Apr 13, 2003 04:42 PM
