Dual HPOPs
Old Jan 26, 2011 | 04:02 PM
TerminatorEng.'s Avatar
TerminatorEng.
Travis, good questions. On my 95, going from 3200 to 3880 I gained around 15HP. But, that is not the reason I went with more pressure. Again, your on top of it. IMO, more pressure would get the fuel out faster, less smoke, and better throttle response is what I see. Something else I noticed running the higher pressure is that I'm at 3400-3700 before WOT. The only time I see 3880 is at WOT, and that's not very often.
In short, running higher pressure just gives me a faster ICP ramp up and that's what I'm after.
My buddy/Tech in New Jersey is just over 4000psi at WOT on stock AD's.
Old Jan 26, 2011 | 04:06 PM
Talyn's Avatar
Talyn
Are you going to run hybrids or B codes travis?
Old Jan 26, 2011 | 04:12 PM
TerminatorEng.
Originally Posted by cowmilker08
So basically the two pumps both pump to the IPR, then the oil splits to the two heads.
Well, kinda sorta. The discharge ports become one, with the R-IPR block in place. All those chambers(4 ports) are connected.
Old Jan 26, 2011 | 04:15 PM
Talyn's Avatar
Talyn
So, basically the block is equalizing the 2 pumps but the oil is going to the heads from the pumps, not the R-IPR Block?
Old Jan 26, 2011 | 04:19 PM
TerminatorEng.
Yes Sir, exactly.
Old Jan 26, 2011 | 04:26 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Good to hear. I think when I get my motor built, I'm going to start trying this out and see what happens. I will talk to you more about this when the build starts unfolding. I will be calling you for pumps, but it's going to be a few more months.
After lots of research, looks like I'm going to be trying out some hybrids first. B codes sure would love those Termys though!! LOL
Old Jan 26, 2011 | 04:39 PM
Talyn's Avatar
Talyn
From what Joey tells me the hybrids benefit really well from big oil as well.
Using less oil, but having the constant volume/pressure there allows them to really shine. How fast they fill is just as important as how fast they empty as well.
Personally I'm thinking hybrids myself.
Old Jan 26, 2011 | 05:20 PM
strokin'_tatsch
I will not have your ordinary off the shelf hybrids William.. LoL. Hybrids seem to work well by riding in Austin's truck and driving Cody's puller, but mine will be a bit different from theirs...
Old Jan 26, 2011 | 11:13 PM
TerminatorEng.
Travis, do tell?
Old Jan 27, 2011 | 12:05 AM
oldbird1965's Avatar
oldbird1965
So with all this pumping action at high pressures and volume, why isn't code 1211 being thrown, especially with one IPR?
Old Jan 27, 2011 | 12:23 AM
Talyn's Avatar
Talyn
1211 is when your getting more than called for.
Old Jan 27, 2011 | 02:01 AM
strokin'_tatsch
Travis, do tell?
You will know in due time my friend, due time. Not even Cody knows the full story on what's going to happen yet.
Old Jan 27, 2011 | 09:08 AM
  #28
oldbird1965
That's what I'm getting all the time, even with the new IPR I got from Joey. I guess my adrenaline is stronger then duels, LOL.
Old Jan 27, 2011 | 11:20 AM
  #29
Talyn's Avatar
Talyn
Well I believe 1211 is Above or Below desired pressure.
Old Jan 27, 2011 | 11:35 AM
  #30
oldbird1965
Yes it is and in order to not highjack this thread, I should start my own. Sorry Phil!! I'll shut up now!
