STANCOR GPR
Old Jan 24, 2011 | 07:30 AM
seanlleiker's Avatar
seanlleiker
STANCOR GPR
I'm needing a new glow plug relay and I have read that some people are using the STANCOR - 586-903. Do you guys have anything good to say about this. If it works, it would say me about $20 over the NAPA relay. Thanks for your time.
Sean
Old Jan 24, 2011 | 07:34 AM
Robbgt's Avatar
Robbgt
I recommend the Stancor. Better built and will last longer than oem
Check out this thread
https://www.ford-trucks.com/forums/1...cor-relay.html
Old Jan 24, 2011 | 07:41 AM
mq1shooter's Avatar
mq1shooter
^^^ What He said....Just physically larger and better built....
Old Jan 24, 2011 | 08:00 AM
seanlleiker
Thanks guys, I will get one ordered.
Sean
Old Jan 24, 2011 | 08:23 AM
seanlleiker
OK, this maybe a stupid question but here it goes. The 902 relay is a 12V and the 903 is a 15V, both 200amp. Would it be better to go with the 15V or is that to much and I should stay with the 12V. Thanks
Sean
Old Jan 24, 2011 | 08:28 AM
Robbgt's Avatar
Robbgt
I'd say run the 802-586-902, I think that's what most are running myself included. I don't know that the 15v would be 'better', as it's a 12v system. Someone can correct me if they think the 15v would be better but i don't see how it would
Old Jan 24, 2011 | 08:51 AM
Ken_C's Avatar
Ken_C
no stay with the 12v one for sure. measure how many volts you have while the GPs are engaged and you are cranking. it will drop below 12v.
Old Jan 24, 2011 | 09:47 AM
JamesHajek's Avatar
JamesHajek
What these guys said, Stick with the 12v one. That's the one i have and it works great.
Old Jan 24, 2011 | 09:52 AM
seanlleiker
Sounds good, I will get the 12V. Thanks again you guys are a great help.
Sean
Desert Rancher's Avatar
Desert Rancher
Does anyone have an old Stancor around. I would like to have one working or not to check the fit on a Cali truck.
Old Jan 24, 2011 | 09:56 AM
Robbgt's Avatar
Robbgt
Desert, Although I don't have a spare, This document has dimensions if that will help you
http://www.stancor.com/pdfs/Catalog_2006/Pg_056_57.pdf
Old Jan 24, 2011 | 10:23 AM
Desert Rancher
I really need to have one in hand. The Cali trucks have a "shunt" mounted across the gp terminals.
Old Jan 24, 2011 | 10:34 AM
JamesHajek's Avatar
JamesHajek
I have the stock gpr and my Stancor, Are you just trying to see if the studs are the same distance apart?
Old Jan 24, 2011 | 10:44 AM
Desert Rancher
It's a little more than that. The shunt is a metal piece that mounts across the relay studs and is attached to another bracket that the gp wires connect to.
Old Jan 24, 2011 | 01:03 PM
richdawg's Avatar
richdawg
I installed the Stancor about a week ago and took some pics, maybe they will help.
r-kid
30
Feb 3, 2026 08:46 AM
ZeroTucker
Oct 11, 2016 11:30 PM
Jessef250
Jan 9, 2011 05:06 PM
richdawg
37
Jan 8, 2011 07:24 PM
superduty4x4
50
Mar 9, 2009 08:50 PM
