Sponsored by: Real Truck
lockout hub problems?
Old Jan 23, 2011 | 09:46 PM
T0MCHANDLER's Avatar
T0MCHANDLER
I'm looking for a cause for a repeating problem. I need to have a lockout replaced. this will be the 4th if it is the right or the third if it's the left. I have the vacume engaged factory hubs. I ALWAYS lock them in manually because I have had the vacume solonoid replaced twice. Is there something that could be causing the hubs to go out? Always the same symptoms when I have a problem. Dash light comes on, grinding in front end when I put it in drive (when stuck) Reverse they will usually grab for a while after they won't in drive. Ford keeps covering the hubs but it is a pain to have a 4x4 except when I really need it.
03 F350 club cab long box w/6.0
Old Jan 24, 2011 | 09:14 AM
dchamberlain's Avatar
dchamberlain
You might have them look at this TSB and see if that is the problem.
04-18-5***AXLE - FRONT HUBS NOT ENGAGING, NOT STAYING ENGAGED AND/OR UNLOCKING
I've seen hubs stop working, seize up, etc. Even the dials will seize up. But I can't say I've seen recurring cases of hubs breaking in the way you describe before.
Old Jan 25, 2011 | 08:55 AM
T0MCHANDLER
Thanks Dave.
I was concerned when I bought the truck about injectors because of the stories I had heared. in the last 4 years I have replaced one injector but the 4x4 has been at issue enough to leave me frusterated. my brothers 02 250 and dads 99 450 have not had these issues and their trucks get alot more abuse than mine. I have had it in to 3 different mechanics (2 of which are dealer) and I'm still having issues. at first I blamed the mechanic, now I'm almost to the point of looking up the Lemon Law.
rossgn
Dec 9, 2013 09:18 AM
jessejmc1979
May 11, 2013 09:16 AM
FordMaverickFan
Aug 23, 2012 05:53 PM
dcara
Aug 20, 2012 12:51 PM
GVN2FLY
Apr 17, 2012 09:33 AM
