Fuse #4 Keeps blowing.
Old Jan 23, 2011 | 09:16 PM
zrackovan's Avatar
zrackovan
I just purchased a 2005 Expedition Eb Edition with the Rear Seat Entertainment.
I was trying to use the DVD and noticed that it did not have power. I located fuse 4 which is supposed to control the DVD and the rear audio controls.... it was blown. I replaced the fuse and it popped instantly. Any ideas, has anyone else had this issue?
Thanks,
Zachary
Old Jan 23, 2011 | 09:47 PM
fordno1's Avatar
fordno1
Welcome to FTE! First thing I would do is disconnect power at the DVD player then replace fuse. If it blows again, you have a good idea that there is a short in the wiring between the fuse box and the DVD player. If it doesn't blow, then you have a problem with the DVD player. What else does the #4 fuse operate? Do the same if other electronics are on that circuit. Is it a factory DVD set up or aftermarket?
Old Jan 23, 2011 | 09:49 PM
zrackovan's Avatar
zrackovan
That's a good point, I will try that tomorrow.
chavelka
2004 - 2008 F150
17
Dec 25, 2016 11:24 AM
BrandonsNavi
Dec 15, 2016 10:00 AM
Callmed
Sep 4, 2016 03:26 PM
Michael Gross
Sep 17, 2015 02:22 PM
Ammie
Apr 4, 2010 04:09 PM
