Sponsored by: Auxito
Alarm Blues
Old Jan 23, 2011 | 04:09 PM
ski1491's Avatar
ski1491
Alarm Blues
I have 1 1999 F-150 Lariat with an alarm that is driving me bonkers. I disconnected the battery to repair the odometer and radio displays that were out (big success there) and when I reconnected the battery if I lock the door and reopen it after a few minutes the alarm starts blaring. Then only way to make it stop is to cycle the ignition switch on (will not start) and hit the kill switch in the kick panel (will stop and start then). I tried a few tricks in other forums, turned ignition switch on and held down kill switch for 30 seconds, still no luck. I also cycled the ignition switch on and off four and then eight times, no luck. The alarm is a dealer installed ford system tied into the balck ford module under the dash. The little orange indicator light on the dash does not work, may be a burned out LED. Odd though has three wires going to it. Any suggestions are greatly appreciated, getting to be very irritating. Thanks in advance
Old Jan 24, 2011 | 06:59 AM
ski1491's Avatar
ski1491
Please Help!!!
Any suggestions out there, realized even if I don't lock the doors after 30 seconds alarm will go off when I open the door.
