1978 - 1996 Big Bronco
1986 Ford Bronco
Old Jan 23, 2011 | 04:08 PM
Aune163rd's Avatar
Aune163rd
1986 Ford Bronco
My older brother has a Ford Bronco we are trying to get rid of, however the thing has not run in a couple years. I put a new battery in it and solenoid cause it was burned out or something. After I got all that done I go to turn it over and it will try to start and almost gets there then goes back to just the starter turning it over. If i restart that process it will do it all day until the starter burns out, just will not start. I checked to see if it has fuel from the valve at the top of the engine, it had fuel at that point. Normally I hear the fuel pump in the tank turn on when i turn the key on, im not hearing it right now but i have fuel at the the top of the engine. I went on to check spark plugs and all those are good, i tested to see if they were getting spark and they are on my 1989 F-150 with the same engine, on the Bronco they dont. I also replaced the distributor piece below the cap, (cant remember the name right now ) and all spark plug wires. Anything else that can cause it?
Bronco Specs:
1986
5.0l, 4x4/C6
Old Jan 23, 2011 | 05:30 PM
cOpE!'s Avatar
cOpE!
How old is the gas? Might be old
Old Jan 23, 2011 | 07:43 PM
vtjvt's Avatar
vtjvt
could be the coil, or the ignition control module, No spark=no start
Old Jan 24, 2011 | 01:49 AM
greystreak92's Avatar
greystreak92
Just having fuel at the rail isn't enough. Fuel pressure needs to be a minimum of 35-40 psi at the Schrader valve on the fuel rail.
I'll second vtjvt's suggestion that you could have a dead ignition coil.
The nice thing is you don't have to guess with an EFI-equipped engine. Run a KOEO test and see what comes up.
Thunderbird7480
Feb 9, 2020 02:51 PM
Tim Hodgson
Feb 12, 2015 09:56 AM
fishingnathan
Bronco II
May 13, 2013 11:22 AM
IndySilverAnny
Jan 5, 2005 09:44 AM
