TPS ????
Old Jan 6, 2003 | 08:42 PM
CrazyFordMan's Avatar
CrazyFordMan
TPS ????
what are some tel tale signs that a TPS is not working properly?
1992 F250 r/c l/b 4X4 351 ZF5spd 33" BFG Allterrains clarion CD MTX 6500D amp pushin 2 12" 6000 series subs
Old Jan 6, 2003 | 10:07 PM
steve83's Avatar
steve83
TPS ????
A TPS code from the computer, or it fails the tests in the Haynes manual.
http://www.broncodata.com/tech/codes.htm
Also, poor throttle response & low power.
Old Jan 6, 2003 | 10:08 PM
Racerguy's Avatar
Racerguy
TPS ????
Sometimes a high idle as well.
Old Jan 8, 2003 | 12:16 PM
akford351's Avatar
akford351
TPS ????
Mine went out last spring... telltale signs. Funny idle...idles high. Mine would die on my when I'd go down hills... be drivin and when I let off the gas... dead! Really pissed me off... Use a scanner and check if its going bad...
Ray
Old Jan 8, 2003 | 06:11 PM
steve83's Avatar
steve83
TPS ????
You don't need a scantool for '84-95 MAP trucks - check out that link or a Haynes manual and you'll see how to do it with a paperclip.
Old Jan 8, 2003 | 06:57 PM
CrazyFordMan
TPS ????
well i thought that mabye a bad TPS was causing my truck to "chugg" or buck really bad under acceleration but i think it was water in the gas i got and it wasnt throwing any codes. but now i used some intake cleaner on my truck and i get code "332" insuficent egr flow how do i fix that???
Old Jan 8, 2003 | 09:49 PM
steve83's Avatar
steve83
TPS ????
The computer doesn't actually measure the EGR flow - it just throws that code if the EVP doesn't show that the EGR is opening. Diagnose the EGR, EVP, EVR, and the vacuum system that operates the EGR.
Old Jan 8, 2003 | 10:12 PM
tnmale46's Avatar
tnmale46
TPS ????
