removing valves from flathead 6
Old Jan 23, 2011 | 12:24 PM
52 Merc's Avatar
52 Merc
I want to disassemble these old and broken 254 engines, and I'd like to take out the valves. I read through the service manual and it makes it look really easy...with all the fancy obsolete tools they used to have. So the question is, is there an easy way to do this with simple, basic tool box items? Or will I need to go on the hunt for something special?
Thanks.
Old Jan 23, 2011 | 02:59 PM
59JEEPSTANG's Avatar
59JEEPSTANG
Wayne, If they are like the old Model A engines there is a special tool. If I remember correctly you pull the valve up and this tool goes in by the stem and you tap out the guide. Can't imagine they changed.
Good Luck,
Paul
Edit ALBUQ F-1 is correct, don't know what I was thinking......
Old Jan 23, 2011 | 07:04 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It looks like the classic C-clamp style compressor is used to remove the keepers.
