Pilot Bearing Problem
Old Jan 23, 2011 | 12:09 PM
littleroc's Avatar
littleroc
I Have a 1993 Ford Ranger 2.3 liter 2 wheel drive I've drop my transmission my pilot bear disintegrated so i went to put a new one in and it go in past the fly wheel can some tell me some options
Old Jan 23, 2011 | 02:39 PM
michigan66's Avatar
michigan66
I'm not sure what your problem is. Are you telling us that part of the old bearing is still in the flywheel? If that is the case, you need to get the rest of the old bearing out. You may need to rent a rent a flywheel bearing puller and a clutch driver tool to get the old bearing out and the new one installed.
You should coat the pilot bore hole in the crankshaft with a small amount of lube grease or lithium base grease before inserting the new bearing. Note that the bearing goes into the hole in the crankshaft, which is further in than the hole in the flywheel.
After re-reading your post, is this the problem you are trying to solve?
Old Jan 23, 2011 | 03:13 PM
Hank85713's Avatar
Hank85713
if its like my 94 4.0 pull the flywheel and then get it out. The bearing in mine can be pressed/pushed in from either side!
So when installing be very careful not to push into the detent built into the back of the crank. just put it in flush with the face of the hole.
Old Jan 23, 2011 | 06:23 PM
powersmoked's Avatar
powersmoked
if you pull the flywheel you might want to consider replacing the rear main seal...
Old Jan 23, 2011 | 08:38 PM
michigan66's Avatar
michigan66
The bearing hole is in the crankshaft, not the flywheel so the bearing can only be pulled out/inserted one way. It is, apparently, different from the 4.0 engine set-up.
Old Jan 28, 2011 | 06:27 AM
xxshine's Avatar
xxshine
If it's a manual, look at getting a Centerforce clutch disk and plate. The disk is 1/2 " larger Dia. than stock
NLBurden
Aug 8, 2017 08:09 AM
cogester
Sep 25, 2015 10:32 PM
JB78f150
May 7, 2012 06:23 AM
jiveturkey692000
Mar 5, 2011 09:53 PM
hotroddually
Jan 1, 2009 09:31 PM
