Sponsored by: Real Truck
Headache Rack Lights
Old Jan 23, 2011 | 01:26 AM
FirstF350Truck's Avatar
FirstF350Truck
Hi all,
Recently purchased my first diesel. 2000 White F350 Crew Cab Long Bed 7.3 4x4 automatic with 61000 miles. Lovin it!
I also just purchased a ProTech louvered headache rack with load light and cb antenna attachments. I'm trying to decide what style lights would go well on the rack. Anyone have pics? The light attachments are on the top corners of the rack that is between the top and the side piece, (the angle that is between the two).
Old Jan 23, 2011 | 02:44 AM
Surge08's Avatar
Surge08
First of all I would like to welcome you to the site. I do know someone who has an back rack if its the same thing and I will refer him to you on this thread.
Old Jan 23, 2011 | 03:11 AM
FirstF350Truck
Thank you for the welcome!
Old Jan 23, 2011 | 04:36 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to the nuthouse!!
what kind of lights are you looking to put on. offroad lights, or emergency lights?
i have a strobe bar and an arrow stick mounted on a home made back rack.
here is a picture of the 4th and final (i think)setup.
Old Jan 23, 2011 | 12:24 PM
bigblue61's Avatar
bigblue61
I just purchased some cheap 3x5 driving lights that were chrome, sanded and painted them flat black. I am going to use them as reverse/cargo lights. will post some pics once the special ordered brackets from back rack get in. Ordered them 2 and a half weeks ago and still nothing
Old Jan 23, 2011 | 02:13 PM
tjc transport
i ain't rite
i make my own brackets for everything.
Old Jan 23, 2011 | 03:36 PM
FirstF350Truck
I like your setup tjc transport.
I need emergency lights on top and load lights pointing back and to the side, (thinking of Saber light bar for emergency). I work on the highways so the truck is used for making other drivers aware, protecting me on the road when I'm on ground in front of the truck, and lighting to for working under during night jobs.
I have been looking at Vision X lights for illumination, but they're real expensive. On the other hand, I don't want to put some cheap lights on that either leak, draw to much power, or just illuminate all over instead of having an organized beam that puts good light out where I need it.
Old Jan 23, 2011 | 04:02 PM
tjc transport
i ain't rite
on that bar, i took some 1 1/2 square tube stock and cut 1 1/2 inch sections, drilled holes in the center to mount the bar to, and then welded 4 sections to the rack. 2 outside and 2 evenly spaced in the center to mount the bar.
on my 88, i took some 1/4 X 1 flat stock, and made a set of "T" bars. the bottom of the t bolted to the back rack, and the light bar mounted to the top.
on my 79, i mounted the light bar to the off road light mounting tabs on the double roll bar.
Old Jan 23, 2011 | 04:06 PM
FirstF350Truck
Nice exhaust stack out the rear of the cab!
Old Jan 23, 2011 | 04:19 PM
tjc transport
i ain't rite
when i built that truck in 88-89, i was running a dozer in a swamp a little over a mile off road through a haz mat contaminated swamp. the truck was on 42 inch tires, and the pipes were up there to keep bad stuff out of them. you could not see them from the front, they were completely hidden by the racer-back. the only way you knew they were there from the front was when i stood on it and it puffed a cloud of black because the turbo did not kick in yet.
ufvj217
Jul 22, 2022 07:56 PM
6deuce350
Jul 24, 2017 11:30 PM
ReezyF250
Mar 4, 2012 08:36 PM
browneyez417
Dec 28, 2009 01:20 PM
