Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
A/C Question
Old Jan 22, 2011 | 09:05 PM
fordpride's Avatar
fordpride
A/C Question
I need to know how to jump the low pressure switch on a 2010 Escape it has 3 wires going to it it has 22k miles on it an the clutch stop engauging i check all fuse and swaped the A/C cluch relay with the reverse light relay and still not working
Thanks Mike
Old Jan 22, 2011 | 10:12 PM
wptski's Avatar
wptski
Thanks Mike
Are you out of warranty or just want to know for sure that it's low on freon? I assume that you don't have a meter/tester to check for voltage at the clutch? Might be easier to pull the connector, run a wire from one contact to a good ground, run another wire from the other contact to the + battery post and that should pull the clutch in. Can be done with the engine OFF also. If that doesn't work the clutch coil is open.
Old Jan 22, 2011 | 10:24 PM
fordpride's Avatar
fordpride
I just want to know for the problem myself before i bring it in, my dealership here is filled with dummies
Old Jan 23, 2011 | 06:26 AM
tomw's Avatar
tomw
Post the question on the A/C pages a bit further down the list of forums. If you have a meter, you can measure the resistance of the LPCO switch. I don't have access to the pinout.
Wouldn't this still be under warranty?
tom
Old Jan 23, 2011 | 07:22 AM
fordpride's Avatar
fordpride
Yes it's still under warranty
Old Jan 23, 2011 | 07:39 AM
projectSHO89's Avatar
projectSHO89
Then take it to the dealer since it's under warranty and you don't know how the circuit works.
Old Jan 23, 2011 | 08:23 AM
jbielec's Avatar
jbielec
Yes please take it in.
I am sure if you are poking around and something happens, cause you are poking around. Then you will take it in and the dealer finds whats really wrong(fixes it) and then finds something else cause u were poking around.
I can see if now......
That dealer sucks or that dam car sucks or why are they wanting to charge me for that ?? I didn't do that.
Please just take it in and what you say, have the dummies fix it the right way.
hoytenticer
1983 - 2012 Ranger & B-Series
Aug 6, 2024 12:13 PM
burgerking579
Aerostar
18
Jul 20, 2021 12:05 PM
broncoray
Nov 23, 2003 07:44 PM
mlkull
Jan 15, 2003 07:43 PM
