1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
99 f350 4r100 tranny problem
Old 01-22-2011, 08:51 PM
blockzilla's Avatar
blockzilla
blockzilla is offline
99' f-350 7.3 diesel .......Ok yesterday I pulled up to the store -- left truck running in park.. came back out put it in drive .. nothing .. like its in neutral... but it did have low gear so drove it home slowly in low... fluid level good. Never had any problems before .. then all at once ??? pulled the pan today dropped the valve body .. found one of the 3 feed bolts a tad loose ( finger loose) .. tightened it back up ... now heres the problem . after dropping the accumulater plate i only had 7 ---5/16" Checkballs on the floor in the fluid puddle and all the info i can find on the web shows 8 .. but I cant find info on the 99' model .. anybody got the info on how many I should have ?? and location. I have found some pics showing 8 .. If i'm suppose to have 8 then I'm screwed.. if 7 which one do I leave out ? any one of you tranny guys have a spare 5/16" ball you could send me if I need an 8th one ? thanks ... gonna have to walk to work if I cant get this fixed quick...
Old 01-22-2011, 09:51 PM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
You can get the check ball from Ford. My dealer keeps them in stock.
I have never torn into the 4R100, but I know on the 4r70w that you need all 8.
If your dealer is big enough to have a trans guy then he should be able to tell you off the top of his head. Its less than $2 for that part.
Old 01-23-2011, 05:49 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,584 Likes on 1,061 Posts
Don't leave any out, if there were 8 in there it will need 8 to operate. Once you get it back together will it drive with the shifter in 1, then move the shifter to 2, then to OD with OD turned off? Will it go through the gears that way?
Old 01-23-2011, 08:09 AM
blockzilla's Avatar
blockzilla
checkballs
Mark -thats what I am needing to know .. are there suppose to be 8 5/16" ***** in a 99' model or 7 ***** . I only had 7 ... hoping someone could tell me for sure ...
Old 01-23-2011, 04:33 PM
blockzilla's Avatar
blockzilla
I have been all over the floor ... got a smooth clean shop floor under the truck and the other 7 ***** were all together . Makes me wonder ... is there a chance this truck could have had a tranny upgrade "shift kit " or something that would call to leave a check ball out and only use 7 ? I'm not sure ..anybody ??? I don't want to put one in and mess up something that was maybe already modified . But will be more than happy to find one and put it in if it needs to be there . When I bought this truck it already had the gauges for boost - egt - trans temp-- superchips programmer-- air ride-- vacuum assist brakes etc so thats why I was wondering if maybe a tranny mod could have been done that might have changed the checkball count... ??
blockzilla
13
10-04-2021 09:24 AM
Rusty_S
Garage & Workshop
33
01-12-2017 01:05 AM
Flat Ernie
19
01-22-2015 06:57 PM
mueckster
Ford Truck Parts for Sale
09-30-2013 09:21 PM
bill ballinger
05-30-2001 03:12 AM
Quick Reply: 99 f350 4r100 tranny problem
