C-4 trans
Old Jan 22, 2011 | 06:07 PM
gregfire's Avatar
gregfire
C-4 trans
I bought a 1972 f100 long bed 302 V8 with a C-4 trans.
To put in my 1957 f100 short bed
Trans has 11 bolts on the pan, dip stick tube side of pan but out put shaft it has a solid yoke.
What trans is it?
Old Jan 22, 2011 | 06:17 PM
BobbyFord's Avatar
BobbyFord
Post the tag info (tag is on the intermediate servo cover) so NumberDummy can decode it for you.
Old Jan 23, 2011 | 04:44 AM
jowilker's Avatar
jowilker
Greg, Google Ford C4 transmission pan, from the images looks like 11 holes to me.
Save Bill for more important stuff.
John
Old Mar 28, 2011 | 06:30 PM
302/C4's Avatar
302/C4
I have same type of C4 with fill tube in pan-I NEED A PAN and FILL TUBE with Dip Stick. Mine comes out as a 68/69 car trans with a code # PEA M1. As best I can find out is that Ford put them in '69-mid 70's F-100, mid-full size cars and in Broncos. Made with heavier output shaft and yoke with additional clutches. The body of trans is longer to form part of bell housing with a shorter bell housing.
Old Mar 28, 2011 | 10:32 PM
zenmaster's Avatar
zenmaster
gregfire,
Look here: Ford C4 transmission
Cheers,
John
Old Mar 29, 2011 | 12:50 AM
302/C4's Avatar
302/C4
gregfire-post a picture of your trans pan and yoke, with ID Tag info. zenmaster-the link you provided makes reference to the C4, like I have, with the style that has the fill tube/dip stick in the pan. But, it does not show a picture or give any details on the trans.
Old Mar 29, 2011 | 06:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Look at the dipstick you have now and post the ID number stamped on it.
I want to see if it's the same as the 1965/72 car & 1964/72 truck parts catalogs call for.
Old Mar 29, 2011 | 09:34 AM
302/C4's Avatar
302/C4
I do not have the dip stick/fill tube or pan-I need to find those ASAP. Can find a replacement chrome pan at a low price. But, for fill tube set up only available from hi-buck Lokar or from racing transmission shops. Local shops that sell used Ford parts and wrecking yards do not have this type of set up. Will have to hit more Pick'N'Pull yards. Wanted ads on craigslist have not located parts needed either. I do not need the fancy stuff.
Old Mar 29, 2011 | 11:09 AM
NumberDummy
The C4 pan shouldn't be too hard to find, the same one (DOAZ-7A194-A) was used 1969/79 in myriad cars/trucks.
But, there are THREE different fill tubes and FOUR different dipsticks used w/this pan just for 1968/79 F100/150's.
C8AZ-7A020-B .. A/T Dipstick = 1968/72 F100 240/300/302 / 1969/74 Econoline 240/300/302 // 1968/74 Galaxie/LTD 240 (thru 1971) / 289 (1968) / 302 (1968/74).
I found 7 of these.
DOTZ-7A228-A .. Fill Tube = 1969/72 F100 240/300/302.
No one has any.
I didn't look for 1973/79 parts...yet.
And, you are also gonna need this: 87034-S94 .. Fill Tube O-Ring-9/16" I.D. / Available from Ford, fits a gazillion different A/T's from 1951 thru today.
Old Mar 29, 2011 | 01:13 PM
302/C4's Avatar
302/C4
NumberDummy-Wow! Thanks for info. With so many variables that may be part of the reason not readily available in the aftermarket world. Will check Pick'N'Pull web site since they list vehicles in their yards.
Old Apr 2, 2011 | 10:29 AM
302/C4's Avatar
302/C4
302/C4
Finally got to a Pick'N'Pull that had Pre 80's Ford Trucks/Vans. No older Ford cars. There were about 9 to check out for a C4 fill tube/dip stick in the pan. Trans I have did not have a pan. Pan I found came from was marked as a '73 F-100-dip stick number is D38P-7A020-AA. The other trucks at wrecking yard either had no trans, C6 or stick.
Old Apr 2, 2011 | 05:07 PM
NumberDummy
Pan I found came from was marked as a '73 F-100-dip stick number is D3BP-7A020-AA.
D3BP-7A020-AA = D3BZ-7A020-A .. C4 Trans Dipstick = 1973/74: Bronco 302 & F100 240/300/302.
Old Apr 2, 2011 | 10:11 PM
302/C4's Avatar
302/C4
NumberDummy-Thanks again for help confirming source of trans pan.
Old Apr 9, 2011 | 10:44 PM
302/C4's Avatar
302/C4
Number Dummy-if you can do any type of transmission ID with numbers on casing of C4 please give this a shot: on the side is C6 PP-7006A in the 2 circles above number: 1st one has a 3 in next one is 1BX66-do not have ID Tag or dip stick-if these numbers do not help you is there anything else to look for to help ID?-Thanks
Old Apr 10, 2011 | 05:17 PM
302/C4's Avatar
302/C4
C-4 Trans
from what I could find online the main body casting number that includes C6 shows this other trans I have is a 1966. Fill tube in casting, not pan -should be a car/Mustang tranny.
