C-4 trans
Old Apr 14, 2011 | 06:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 302/C4
Number Dummy-if you can do any type of transmission ID with numbers on casing of C4 please give this a shot: on the side is C6PP-7006-A
This is the casting number found on and for the transmission case only, it is not the trans ID number.
I cannot do anything with it, as casting numbers cannot be cross referenced to Ford part numbers.
With the C6 prefix, there are two different C4 trans cases that could apply, one was only used in 1965/69 Galaxie/LTD's. The other is everything else thru 1970.
The C4's ID tag was bolted to one of the 4 bolts that retains the servo cover (drivers side) to the case. It's prolly missing by now.
Inside Man
Jul 28, 2016 12:11 PM
A73F100
Jan 14, 2014 07:50 PM
bbf150
Nov 5, 2013 02:20 PM
ben8892002
Dec 28, 2007 08:30 PM
fordaholic-67F100
16
Mar 14, 2004 07:56 PM
