Sponsored by: Real Truck
Fast turn signal
Old Jan 22, 2011 | 12:01 PM
lexustbs's Avatar
lexustbs
Fast turn signal
I have a 2011 f250. The right and left turn signals are blinkling really fast when I activate them. No bulbs are out. I think it might be the flasher? But I don't know where it is located on the truck? Also the emergency flashers act at a Normal rate. Its just the left and right signals.
Old Jan 22, 2011 | 03:57 PM
5moons's Avatar
5moons
Last time I had that happen it was on an older truck, but it was a bad relay. It was located under the drivers side dash. Square metal, plug in type. But who knows with these trucks. Good luck.
Old Jan 22, 2011 | 07:28 PM
itsabowtime2's Avatar
itsabowtime2
2011; I would take it back to the dealer and tell them to make it right.
Old Jan 23, 2011 | 10:47 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
The flasher should be a cheap thing to try, and a lot easier than leaving the truck at a dealer for a day (or more).
Old Jan 23, 2011 | 01:41 PM
GDog1911's Avatar
GDog1911
Probably a bad ground somewhere. Thats been the cause on a few vehicles I've owned. Hope its still under warrenty because it could be a real pain to find it.
Old Jan 23, 2011 | 05:00 PM
Surge08's Avatar
Surge08
I would say take it to the dealer, Warranty = no money out of pocket
Old Jan 23, 2011 | 07:20 PM
TexasRebel's Avatar
TexasRebel
do you happen to have LEDs instead of incandescent?
LED's don't show the same load to the computer, and so the computer signals that a light is out... However, your flashers might either show enough load or not have the bulb-out signal coded in.
2011's do not have flashers... those have been extinct for a while... it's all programming now.
Old Jan 23, 2011 | 07:23 PM
lexustbs's Avatar
lexustbs
No LED. they just recently replaced my BCM so I'm thinking they messed up the programming on it.
Old Apr 22, 2011 | 06:32 AM
jrwendell's Avatar
jrwendell
So, there is no flasher to replace? I want to instal LED's and an not keen on having to install resistors trick the system. Could the "computer" be reprogramed for LED's?
Old Apr 22, 2011 | 06:47 AM
lexustbs's Avatar
lexustbs
Yes. You just have to go to the dealer and tell te to either turn off the "bulb out" feature, or I think there is an option for LED. what lights are you looking at installing?
Old Apr 22, 2011 | 11:07 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Before you buy ANY LED lights, INSURE that they already have the fixture with the resistors already in them..... QUALITY COUNTS.
Old Apr 22, 2011 | 03:44 PM
jrwendell's Avatar
jrwendell
Do you have a vendor or two that you could recommend; 1000’s found on-line? I was considering GO RECON’s bulbs.
51camohunter
23
Jul 9, 2023 12:25 PM
R7d7ta
1997 - 2003 F150
Feb 20, 2011 01:14 PM
lexustbs
6.7L Power Stroke Diesel
Jan 26, 2011 11:07 AM
anteru
Jul 21, 2010 04:53 AM
projectdagger
Mar 19, 2010 12:14 AM
