Engine Swap from 460 to Mod.?
Old Mar 6, 2022 | 12:51 PM
  #31
Franklin2's Avatar
Franklin2
Originally Posted by Valoure
I have a 1994 E150 v8 - with a great engine but, other issues
there is a 1985 Jayco motor home on the market that needs an engine 460
would I be able to swap the econolines engine into the Jayco ?
I am thinking no. The 1994 is a fuel injected 460? And the motor home is carbed? The fuel injection is not easily taken off and swapped to a carb on the 460's. You can search for a kit, someone may make one. But otherwise, you have to swap cylinder heads to convert a fuel injected 460 to a carb. The heads and the intake are different and a carbed intake won't fit. If you want to pull the older heads and have them redone and install them and the carb intake and other engine dress off the motor home, then that would work.
mdsFX4
Sep 20, 2016 07:52 PM
4.9
Aug 24, 2016 01:57 AM
Irish19614x4
20
Jan 30, 2016 06:01 PM
evan russell
1978 - 1996 Big Bronco
Dec 22, 2015 04:35 AM
RhondaBruce
Modular V8 (4.6L, 5.4L)
Dec 12, 2015 08:09 PM
