1978 - 1996 Big Bronco
4.6l swap
Old Dec 13, 2015 | 08:59 PM
evan russell's Avatar
evan russell
4.6l swap
Hey there is used to have a 1987 bronco ii with the 2.9l and 5Mt.. unfortunately I couldn't find any parts for it no matter where I went..and at the time I didn't know about forums... I ended up sending it to the junk yard... miss it everyday... my questions are ifor I where to buy another or even the full size version( which I like more) where can I get good parts for it?.... my other question is if have a 2003 Mustang gt with the 4.6l... is it possible to swap my 4.6l into a bronco ii..? And if so what will I need because I thought it would be a great idea/project.. thanks
Old Dec 14, 2015 | 07:17 AM
My4Fordtrucks's Avatar
My4Fordtrucks
You couldn't find parts for a Bronco II anywhere? Any local auto parts store, Ford dealer or internet parts place like Rock Auto would have most of the maintenance parts or be able to get them for you. The same is true for a FSB. There are specialty places like Jeff's Bronco Graveyard that carry trim pieces that you might not be able to get. Some things just aren't reproduced so the junkyard might be your only option there.
As for the 4.6 in a Bronco II, my guess is that it wouldn't fit since the modular engines are so wide.
Old Dec 16, 2015 | 10:33 AM
Kemicalburns's Avatar
Kemicalburns
if you can fabricate really well and know how to read a schematic most any motor can be put into a rig.
With that said the better swap for the BII is typically a 4.0 motor/trans from an explorer. Some have dropped a 5.0 in a BII but i feel that a bit on the overkill side.
I dont really see the 4.6 being a good motor for an FSB due to it being more suited for a light weight car. the bronco weighs close to 3 tons. not to mention finding the necessary transmission to work because the car trans wont.
Old Dec 21, 2015 | 07:35 AM
Ron94150's Avatar
Ron94150
I dont really see the 4.6 being a good motor for an FSB due to it being more suited for a light weight car. the bronco weighs close to 3 tons. not to mention finding the necessary transmission to work because the car trans wont.[/quote]
It pulled full size trucks and expeditions around for years, 2&4wd. More power than a 5.0 that came stock in a bronco. If it's a mud truck that you want to scream and sling the mud out of the tire tread, it will turn some rpms and makes its power up there. Sorry, I'm just a fan of the 4.6. A 281 cu inch motor drove a 350 Camaro to extinction. Not that I see this getting done by someone that could not source parts for a bronco II.
Old Dec 21, 2015 | 09:08 AM
My4Fordtrucks
Originally Posted by evan russell
.. is it possible to swap my 4.6l into a BRONCO II.?
While I think it might be possible to swap a 4.6L into either a FSB or Bronco II with fab skills, his question for this swap was specifically about putting it in a Bronco II. I'm not sure if you guys are skipping over that part of the question.
Old Dec 22, 2015 | 04:35 AM
gatorfor88's Avatar
gatorfor88
I own an 87 BII 2 wd. you can probably shoehorn a 4.6 in it. I wouldnt want to have to do any maintenance on it. Anything is doable with good fab skills.I have seen a BII with a 302 installed. All the power you need for such a small package. Wouldnt have wanted to change plugs in it either. If you gonna go to all the fab work to squeeze a 4.6 in you might as well throw a 460 in it. Just about the same width.
86fordbronco_ii
Aug 1, 2014 06:48 PM
90-B2ron
Bronco II
Jun 1, 2012 07:39 AM
johnarahill
1966 - 1977 Early Broncos
May 7, 2006 06:38 PM
bronco_baybee
Jun 6, 2004 08:21 PM
stukinthefrontyard
Bronco II
Jan 24, 2003 01:41 AM
