extra wire
Old Jan 21, 2011 | 08:57 PM
johaner78's Avatar
johaner78
extra wire
So after getting all the wiring reinstalled in my truck, i have a wire that I believe would go to the transfer case (NP205). It comes off the main harness that runs along the left inside frame rail. It has a rubber connection that looks similar to the gas tank connections. I've got all the wires plugged into the fuel sending units tho. The transfer case has no electrical connections on it. My question is this: did any or all NP205's have an electrical connection that would turn on a 4x4 light on the dash? I 've rebuild the instrument cluster but for the life of me I do not remember seeing a 4x4 light. I understand the full time 4x4's had an indicator light that was mounted underneath the center of the dash. So what do I do with this extra wire, tuck it out of sight and forget about it? lol
Old Jan 22, 2011 | 12:55 AM
ford1977owner's Avatar
ford1977owner
lol when we put a new motor in our 93 exploder the motor came out of a 94 or 95 cant remember but there was a wire on the new motor and there was on plug we couldnt figure out where it went....turned out to be some cam shaft sensor so we just never plugged it in....still running fine lol.....so just tuck it out of the way and do a test run if its not right then look over it again
Old Jan 22, 2011 | 04:42 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Post the color of the wire, and it's tracer color and I can tell you what circut it belongs to, or if you need it.
Old Jan 22, 2011 | 09:05 PM
johaner78's Avatar
johaner78
81-explorer - the wire is black and goes to the "Differential Lockout Indicator Lamp switch" . Don't think i need this wire because there are no electrical switches on the transfer case and this truck never had the 4x4 light on the lower center of the dash. I think only the full time 4x4's had the indicator light but not sure. Why wouldn't they have used the 4x4 indicator light on the part time NP205's to let you know when you were in 4x4 or not? Seems moronic to me....oh well.
Does anybody here have a '78 NP205 with the 4x4 indicator light on the lower edge of the dash (factory installed - not added later! lol)? Thanks
Old Jan 24, 2011 | 09:32 PM
johaner78's Avatar
johaner78
Anyone? Does anyone have an NP205 transfer case in a '78 F250 with the 4x4 indicator lamp on the lower center edge of the dash?? I have an extra wire along the frame rail which i believe goes to the transfer case but there are no electrical connections on the transfer case - why not?
oem78
45
Sep 6, 2022 06:43 PM
juanv8
18
May 6, 2010 05:47 PM
zak8tac
Jan 14, 2009 08:21 AM
oem78
Oct 5, 2008 04:35 PM
FEmtnmax
Nov 10, 2005 11:31 PM
