What Needs To Be swapped?
Old Jan 21, 2011 | 07:40 PM
Bossman77's Avatar
Bossman77
I have a 92' F150 with 302 and recently bought an engine from a 94 and noticed the intakes and vacuum lines were different. What needs to be swapped to make the engine work in the 92? Will the wiring harness fit from the 92 to the 94 engine if the Intake Manifold is swapped? Any incite will help immensly
Old Jan 21, 2011 | 09:54 PM
Conanski's Avatar
Conanski
The intakes should not be different unless the motor did not come from another E or F series truck.. or the '94 motor isn't a 5.0. Do you know what it came from and that it is indeed a 5.0?
Old Jan 21, 2011 | 10:58 PM
aguitarestv's Avatar
aguitarestv
or get a top end gasket kit and swap the intakes. might be easer to clean the carbon out wile you had it off to.
Old Jan 22, 2011 | 10:04 PM
Bossman77's Avatar
Bossman77
Yea it turns out, gonna have to swap some parts over anyway. Planning on swapping harness from the 92 to the 94 because there were a couple wires a little blackened by the exhaust and dont wanna take a chance. Swappin the headers over along with alternator and tensioner. Does anyone know what the hell the exhaust tube in the rear of the engine is?
