Sponsored by: Auxito
Code P0171
Old Jan 21, 2011 | 06:58 PM
cltaylor's Avatar
cltaylor
Code P0171
I have a 2001 Ford F150 engine light came on, code P0171. Idles rough and gas stinks. Changed out PVC valve and hose, changed IAC valve, cleaned MAF sensor, checked all hoses for leaks. Still idles rough and gas still stinks and light is still on. Any suggestions?
Old Jan 21, 2011 | 07:06 PM
Wilber15's Avatar
Wilber15
Could be bad cat? Disconnect cat at exhaust manifold, see if idle smoothes out. could also be exhaust leak at the exhaust manifold drawing in o2. intake leak? bad injector(stuck closed).
Old Jan 21, 2011 | 07:29 PM
Racerguy's Avatar
Racerguy
Welcome to FTE cltaylor
I've moved your question to the right forum for you. The guys here should be able to answer it for you.
Old Jan 21, 2011 | 07:34 PM
fz1dave's Avatar
fz1dave
Super Duty
Another possibility is leaking intake gaskets.
acm05fsu
1997 - 2003 F150
Dec 26, 2019 02:24 PM
MartinTravels
May 31, 2014 06:52 AM
fordguyforlife
3.8 & 4.2L V6
Oct 20, 2006 11:08 PM
BltFordTough
1983 - 2012 Ranger & B-Series
20
Nov 3, 2005 07:18 PM
YostRH
Dec 22, 2004 09:53 AM
