Help with CE codes
Old Jan 21, 2011 | 10:08 AM
89F20plowtruck's Avatar
89F20plowtruck
Help with CE codes
Hey everyone, I was out plowing this morning and the check engine light came on. I got a 32 and 85 on the KOEO and 32 and 41 on the CM. From what I found the 32 means <table border="1" cellpadding="2" cellspacing="0"><tbody><tr><td>EVP circuit below minimum voltage of 0.24 volts.</td> </tr> <tr> <td> </td> <td><center>X</center></td> <td> </td> <td>EVP circuit has intermittently failed below minimum voltage of 0.24 volts.</td></tr></tbody></table>and the the 41 is<table border="1" cellpadding="2" cellspacing="0"><tbody><tr><td>
</td> <td><center>X</center></td> <td> </td> <td>HEGO sensor circuit indicates system lean (right side).</td> </tr> <tr> <td> </td> <td> </td> <td><center>X</center></td> <td>No HEGO switching detected always lean (right side).</td></tr></tbody></table> and the 85 isCanister Purge Solenoid circuit failure.
Now what do I do?
</td><td>
</td><td>
</td><td>
</td></tr><tr><td>
</td> <td>
</td> <td>
</td><td>
51dueller
112
Jan 23, 2025 04:08 PM
ReAX
Modular V8 (4.6L, 5.4L)
Dec 11, 2012 11:56 AM
Smokey1961
Jan 17, 2009 04:05 PM
Bowie
Nov 6, 2008 03:05 PM
chaparro
Feb 15, 2007 11:18 PM
