Bubbles in oil? [IMPORTANT]
Jan 20, 2011 | 01:39 PM
I got a little hint from a friend earlier today, and they said something about bubbles in the oil.
Without telling you guys what he said, I wanna know what you guys said.
When I went to check my dipstick, there were bubbles all over the dipstick..
What does that mean?
Jan 20, 2011 | 02:02 PM
Are you talking a few small bubbles? Or a lot of odd colored ones, like muddy grey or cloudy oil?
Sarge
Jan 20, 2011 | 02:06 PM
Not important, doesn't mean a thing. If you think there is something wrong with the engine, it will give other signs.
Jan 20, 2011 | 02:11 PM
Could it mean gas in the oil though?
Jan 20, 2011 | 02:13 PM
No, the gas ond oil mix so you wont be able to see it.
Jan 20, 2011 | 02:16 PM
Depends on the bubbles
A few bubbles are normal.
Lots of little bubbles, overfilled and the crank is aerating the oil (easy enough to notice on your dipstick)
Muddy brown/chocolate milk bubbles, coolant in your oil.
Jan 20, 2011 | 02:18 PM
Quote:
Originally Posted by
Wicked Endings
If you're worried about gas in your oil, smell your oil. Simple enough
Jan 20, 2011 | 02:29 PM
Okay... So... I don't need to worry about that.
However, gas in the oil could wear out the bearings, because I believe that my fuel pump is leaking into the oil... Which could wear out the bearings and lead to the engine seizing, correct?
So, bubbles in the oil or not, I have a gas leak and the suspect is the fuel pump leaking into the oil.
So, I need to replace the fuel pump, fuel filter, oil, and oil filter.
Correct?
Jan 21, 2011 | 06:53 AM
If you can smell gas in the oil, then yes, you need to fix it.
Sarge
Jan 21, 2011 | 07:47 AM
Jan 21, 2011 | 08:10 AM
Wow!
You've actually had problems with your truck? O_o
Jan 21, 2011 | 07:42 PM
dohc_chump
wouldn't fumes from the breather tube from the air cleaner going into the valve cover where you pour oil in make the oil pick up the smell of gas?
Jan 21, 2011 | 10:49 PM
Wicked Endings
Wow!
How else do you think I learn all this stuff?
Jan 22, 2011 | 11:41 AM
guindian28
If your oil is fuel fouled you will know it by smelling it. There is a huge difference from the byproduct and raw fuel being dumped into the oil.
Jan 22, 2011 | 01:33 PM
dohc_chump
If your gas is fuel fouled....
Insert Tim Taylor
Home Improvement sound effect.....
Huh???????
You mean
oil , right?
