e4od advice
Old Jan 20, 2011 | 12:57 PM
gumper 123's Avatar
gumper 123
e4od advice
Ok you guys might have seen me on here few days ago had my od light on dim no tach. Has not acted up sense then. went out to plow last night did good for 8 hrs felt it drop out so i got out and switched relays around never did it again. pushed for another eight or so. left my last parking lot got on highway. engine reved up like i threw it in neutral let off gas pulled over checked fluid looks good perfect level. took off drove fine 30 miles did it again. drove on home another 15 miles acted fine replaced mlps 8 months ago but thats what i am hoping for. Any thoughts i havent had any sleep so brain dead. also broke that yoke piece between the two u joints out of the transfer case looks like simple fix and $70.00
Old Jan 20, 2011 | 08:54 PM
KJLYPW's Avatar
KJLYPW
If your lights have any bad grounds the torque converter lock up can disengage thinking that you've applied the brakes- senses voltage backwards up the brake light wiring!
Old Jan 20, 2011 | 09:08 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
"so i got out and switched relays around"?
Old Jan 21, 2011 | 08:29 AM
gumper 123's Avatar
gumper 123
well i read in a post months back that someone had a relay the ones in the fuse box under hood so i switched a couple around was not sure witch one it was didnt have my manual in truck.
PiP.Squeak
29
Apr 4, 2015 11:08 AM
mattri
13
Jun 20, 2014 09:34 PM
MOERULES
Sep 25, 2012 06:00 AM
machmedic
Mar 14, 2012 08:58 PM
homer1972
1997 - 2003 F150
Nov 16, 2007 03:52 PM
