electrical? fuel? idk help!
Old Jan 20, 2011 | 10:54 AM
powerstrokedan96's Avatar
powerstrokedan96
96 powerstroke. check engine light comes on and off intermittently and runs rough. had it scanned and it came up with #7 injector circuit low. i replaced the entire uvcwh including the plugs on the out side. got it back together still runs extremely rough and hard to start but no CEL. swapped idm's and did the same thing. checked hpop and its full. checked ipr and its good. checked fuel filter its clean and its the correct filter. took filter out and cranked the motor and the bowl filled up so the fule pump is working fine. im out of ideas now? whats next re-check my wiring?
thanks, dan
Old Jan 20, 2011 | 12:07 PM
custom_nirvana's Avatar
custom_nirvana
could be the actual injector. if you can try running a buzz test on it since you seen to have access to a scanner
Old Jan 20, 2011 | 03:49 PM
powerstrokedan96
the first time i scanned it we ran a buzz test, all the injectors sounded good.
Old Jan 20, 2011 | 06:19 PM
RRranch's Avatar
RRranch
look at your wiring harness real good for spots that the squirrels got to. It's that time of year. I'd unhook it from the pcm and idm too and look at all the pins. Or maybe first, swap solonoids with another one to see if the miss moves. .
You do realize that the buzz test goes in the firing order right? Just so you aren't looking for a problem on the wrong one.
jdw1
Apr 19, 2011 08:15 PM
Tater50
37
Dec 25, 2010 07:19 PM
ddo1
41
Dec 12, 2006 08:31 PM
marcus2576
Aug 18, 2004 05:26 PM
