1978 F250 rims and tires - Ford Truck Enthusiasts Forums
Old 08-27-2010, 01:57 AM
greg in the oc
greg in the oc is offline
greg in the oc is starting off with a positive reputation.
I have a 1978 F250 and need new tires because they are cracking/deteriorating. The size is 9.5r 16.5 which are tough to find \AND expensive. It almost seems more cost effective to buy lets say a 16'' rim and then get a tire size I can relate to (275 80 16) or whatever. I know someone has done this, but I need to make sure the bolt pattern is the same. Is it 6.5'' (165.mm)? I see a lot of 8 lug x 170mm out there, but those won't work right? Any recommendations for an inexpensive alternative? PLEASE HELP - I want to get this beauty on the road, but it just isnt safe.
Old 08-27-2010, 02:15 AM
Rockstone's Avatar
Rockstone
Rockstone is offline
Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.
You want the 8 X 6.5". Ford changed to the 8 X 170mm in I think, 1999. I made the change to a 16" wheel on mine as well. I am running 265/75R16.
Old 08-27-2010, 11:51 AM
berry1234's Avatar
berry1234
berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
I am in the same boat. I have the 16.5" tires and it really limits what tires you can buy. I don't want a custom wheel look, but I don't know what other options there are other than find some 16" OEM optional mag or white spoke wheels and most of those are not 8x6.5.
Old 08-27-2010, 01:39 PM
Joseph69's Avatar
Joseph69
Joseph69 is offline
Joseph69 is starting off with a positive reputation.
The Vans with 8 lug used the standard pattern longer.
Old 08-27-2010, 03:15 PM
AntiHero55's Avatar
AntiHero55
AntiHero55 is offline
AntiHero55 is starting off with a positive reputation.
BF Goodrich makes a 16.5 all terrain tire....
i just bought a 35x12.5x16.5 from them for my 1978 F250...
Old 08-27-2010, 03:28 PM
greg in the oc
Thanks for all the input. I don't have a problem with changing over to a non-stock 16'' size, in fact I think that's what I will do so I can shop around being the frugal SOB I am. Does anyone know where to get the older 165.1mm 8 lug bolt pattern on a 16'' rim though (I almost made the mistake of buying some 170mm rims/tires on Craigslist)? Also, I don't want to get an oversize offroad tire like 33'', etc. I want to stay with the current overall diameter which is about 29'' or 30''. Thanks again!
Old 08-27-2010, 03:38 PM
Explorator
Explorator is offline
Explorator is starting off with a positive reputation.
I just put four Cooper radial 9.50 X 16.5's on my 1978 F250 and it cost me $700. Decent 16" tires with a similar load range and equal ply's would have saved me about $150. I could find some used rims, and break even, or save some money by finding used 16"ers which are far more common.
I love 16.5's; they are just sturdier than the 16"s. I also find that the sidewalls are thicker on the 16.5"s, which is nice.
Old 03-26-2012, 11:16 PM
PEARLOFTHEDESERT's Avatar
PEARLOFTHEDESERT
PEARLOFTHEDESERT is offline
PEARLOFTHEDESERT is new and has a neutral reputation at this point.
i had to buy 33's for my wheels which were 16.5, and they were too big for the stock 2 wheel drive. i ended up going with 17 inch cragar wheels to find a tire size i liked. the 33's i had ended up being just 200 bucks cheaper than the wheel and tire package i have on it now.
Old 03-27-2012, 01:23 PM
papasmurf40's Avatar
papasmurf40
papasmurf40 is offline
papasmurf40 is starting off with a positive reputation.
Ok.... ford used 6.5 x 8 lug up til 97 on obs style trucks...the superduties use 170mm x 8 on srw trucks and 200mm x 8 on drw trucks. Dodge is another manufacturer to use 6.5 x 8 and i think they still use them presently which means you can get 16, 17, 18, 19 and 20 inch rims maybe even 22's. Now using dodge rims you may have to trim slightly as the hub may not be exactly the same as fords but im not absolutely sure of that.
Ken
2008 F150 FX4
Old 03-27-2012, 05:15 PM
AK FORD GUY's Avatar
AK FORD GUY
AK FORD GUY is online now
AK FORD GUY is gaining momentum as a positive member of FTE.AK FORD GUY is gaining momentum as a positive member of FTE.
2wd or 4wd?
Are you looking for "big" tires or something closer to the 9.50R16.5's?
Old 03-27-2012, 05:52 PM
Dr_Gonzo's Avatar
Dr_Gonzo
Dr_Gonzo is offline
Dr_Gonzo is starting off with a positive reputation.
What's with all the dislike for the 16.5s? Just that its harder to find? Or more expensive? Or both? Mine has 16.5s on it, and the tires are dry rotted so I'm wondering what I should do when I replace them.
Old 03-27-2012, 06:25 PM
VocaTexas
VocaTexas is offline
VocaTexas is gaining momentum as a positive member of FTE.VocaTexas is gaining momentum as a positive member of FTE.
16.5 size tires are getting harder to find, and expensive as well. When I got my Crew it needed new tires. It was cheaper to buy new 16 inch wheels and tires than just 16.5 tires. Plus, if you're ever away from home and ruin one, 16s are much easier to find.
Old 03-27-2012, 06:28 PM
papasmurf40
for a replacement for 9.50-16.5, try a LT235-85R16 or LT265-75R16 both are around a 31.5-32 inch diameter tire and the 235 10 ply is good for 3042 lbs per tire and the 265 in 10 ply is good for 3400 lbs per tire so weight wise it will carry as much or more than a 16.5 and you can also get the 265 in 8 ply and 6 ply for more of a daily driver as opposed to a hauler
Ken
2008 F150 FX4
Old 03-27-2012, 10:11 PM
74 F350 SCS's Avatar
74 F350 SCS
74 F350 SCS is offline
74 F350 SCS is gaining momentum as a positive member of FTE.74 F350 SCS is gaining momentum as a positive member of FTE.
Firestone makes a steel belted Transforce HT 9.50 x 16.5 truck tire 10 ply and the cost is around $165 per tire. That's about the going price for any truck tire. Might check it out if you want to keep the 16.5's.
Old 03-27-2012, 10:17 PM
74 F350 SCS
Quick Reply: 1978 F250 rims and tires
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
